1. Sean Mansfield's Avatar
    I downloaded the antivirus app to help with security. I tested it by installing some apps which required alot of permissions and the antivirus showed it had malware. Some apps didn't show this message so I uninstalled manually, I feel real stupid for testing these because even though my antivirus didnt say it had malware, I still can't trust it having my location and contacts for example. Am I in danger even tho I uninstalled immediately? Thanks
    01-04-2014 02:52 AM
  2. xceeder's Avatar
    Hhhhmm I doubt your in danger if you've uninstalled the applications , it would be easier to give you a proper answer if you told me the following a. Which version of android are you on and b. Are you rooted?
    sent from my Nexus 7 ultimate modded edition
    01-04-2014 03:19 AM
  3. Sean Mansfield's Avatar
    My version is 4.2.2 and unfortunately am unaware of rooting. Thanks for your reply.
    01-04-2014 03:35 AM
  4. xceeder's Avatar
    What device are you using pal..
    sent from my Nexus 7 using tapatalk pro..
    01-04-2014 10:49 AM
  1. The dreaded "process com.google.process.gapps" error. HELP
    By Gary Medley in forum T-Mobile Galaxy S II
    Last Post: 01-06-2014, 08:47 PM
  2. screen help
    By mcruz78x in forum Samsung Galaxy S3
    Last Post: 01-04-2014, 01:48 PM
  3. Replies: 7
    Last Post: 01-04-2014, 08:35 AM
  4. Help with tethering kindle fire hd- smartphone or mifi?
    By Aiyana Leigh in forum General Help and How To
    Last Post: 01-03-2014, 08:51 PM
  5. need link and help for ruu 2.3.5 on desire s
    By hillyboy in forum HTC Desire S
    Last Post: 01-03-2014, 08:31 PM
