Results 1 to 8 of 8
    delta7's Avatar
    Posts
    Global Posts
    809 Global Posts
    Default Looking for a program to help organize my home screens.
    I just installed Nova launcher and I'm looking for something to help organize the home screens. For example, Id like one scree for productivity, one for music, one for utilities and a forth.
    Please advise.
    Sent from my SPH-L720 using Tapatalk
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Carrier
    Stock 6.0.1
    Default
    Quote Originally Posted by delta7 View Post
    Please advise.
    I haven't seen any apps that do that, you'd have to do it manually
    Edit: Using Smart Launcher for the first time and it actually organizes thing for you into about 5 or 6 different home screens rather nicely.
    It's a different launcher altogether but it's worth a shot
  3. #3
    Default Re: Looking for a program to help organize my home screens.
    Instead of having a home screen for each category, why not set up a folder for each category and then keep them all on one screen. You can then download an assign an icon to each folder. This functionality is baked into NOVA, Apex etc
  4. #4
    Everything home is awesome and puts your apps in to correct files.
    Also Makes your phone have a fresh new look.
    Hope this helps
    delta7's Avatar
    Posts
    Global Posts
    809 Global Posts
    https://play.google.com/store/apps/d...tle.app.widget
    Looking for something like this app but better, please advise.
  6. #6
    I did it using Buzz Launcher and Zooper Widget Pro. I don't really see what else you need other than that.
    I have only one screen right now but when I first got the S4 I had like 6 just like your talking about. I really love Animated Photo Frame Widget for your gallery screen, totally worth it.
    Multipicture Live Wallpaper is a cool app if you would like to have changing wallpapers customizable on each different screen.
    There's tons of Launcher selections out there, play with them all. I think I liked Simple Calendar for a date screen, I think I used Wizz Widget for Facebook? Not sure.
    We'll there's some info you can go play with anyway.
  7. #7
    Zoooooper
    Sent from my HTCONE using AC Forums mobile app
  8. Thread Author  Thread Author    #8
    delta7's Avatar
    Posts
    Global Posts
    809 Global Posts
    Thanks checking into it.
  1. What do your homescreens look like for 2014?
    By Andrew Martonik in forum Wallpapers, Ringtones, and Themes
    Last Post: 03-12-2016, 04:58 PM
  2. strange notification on Sgs3 security update siver shield looks odd?
    By silversjf in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-01-2014, 08:01 PM
  3. Looking for App
    By nd1983 in forum Android Apps
    Last Post: 01-01-2014, 07:14 PM
  4. LG Voice Mate Programming Responses
    By Kobol System in forum LG G2
    Last Post: 12-31-2013, 11:20 PM
  5. how to get stock rom / unroot / make it look out of the box
    By ddann in forum Samsung Galaxy Tab 3
    Last Post: 12-31-2013, 07:56 PM
