Samsung Galaxy S4 rebooting error HELP!!
android321nerd
Hi so when i turn on my galaxy s4, it goes into Android System Recovery and I try to hit reboot system now or EVEN wipe data/factory rest, but once I do it says error, and then just goes back to the recovery booting screen. and then it also says No Command.
Is there a way I can "get past" the recovery mode and just go straight to my phone.
The volume button is also kind of jammed.. does this have anything to do with it? is there a way to fix this?
thanks so much.
Re: samsung galaxy s4 rebooting error HELP!!
You can possibly try a combo. Hold down the Volume Up, Power and Home button for about 30 seconds. If this doesn't help then take the battery out for about 10 seconds then try and reboot.
Hope this helps.
hey if you still need help I had this exact same problem, volume key being jammed and rebooting issue. after doing some research I found that the volume up key is used for rebooting. so evetually I just took the phone backing off and straightend the volumr key (which is really easy to do) put the backing back on then it was all done! my phone is working fine and turned on straight away!
hey got the same problem now volume up key is jammed. do i have to unscrew the whole back of my phone (galaxy s4)
is there anyway to do this without the volume up button? my button isnt jammed but for some reason it wont work at all. the phone wont let me reboot the system or let me do any of the other options besides factory reset which i havent tried yet but i only want to use that as a last resort
thanks so much.
thanks so much.
r3dpuk3
