Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Golfdriver97
  • 1 Post By SactoKingsFan
  • 1 Post By JudH
    Aesthete18's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Is there a way to rearrange my drawer with Nova Launcher?
    I've had my phone for about 6 months now and the apps are stacking up. In the drawer, I've put the apps into folders according to category. But the apps that are displayed are not always the ones that I use most. Sometimes I have to open up a few to find the apps I want. So I was just wondering I could arrange it in a way that displays apps I want.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,082 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Is there a way to rearrange my drawer with Nova Launcher?
    Not sure about that. Personally, I leave the drawer with the apps in alphabetical order, and I arrange my homescreens for most used apps
    From a Sprint Moto X using AC Forums app
    Aesthete18 likes this.
  3. #3
    SactoKingsFan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can create a new tab that will show up as a separate section in the drawer. I've done this in order to show my most used apps in one spot.
    Nova settings > drawer > drawer groups > add tab > name tab > select apps > move tab to top of list
    Sent from my rooted LG-G2 using Tapatalk
    Aesthete18's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by SactoKingsFan View Post
    That's a good idea. I guess it's not a bad compromise.
  5. #5
    JudH's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Another option is to create a SUB-folder within each category folder and move the less used apps into it. For example I have a TOOLS drawer folder. Within it is a "xt[ MORE ] folder. The more regularly used apps are in the main Tools folder and seldom used apps are in More. Makes it a lot easier to find things. The "xt" prefix is to force it to be last and the "t" for tools since I have more than one More.
    Aesthete18's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by JudH View Post
    Another option is to create a SUB-folder within each category folder and move the less used apps into it. For example I have a TOOLS drawer folder. Within it is a "xt[ MORE ]“ folder. The more regularly used apps are in the main Tools folder and seldom used apps are in More. Makes it a lot easier to find things. The "xt" prefix is to force it to be last and the "t" for tools since I have more than one More.
    That's a good idea as well. Thank you.
  1. Replies: 9
    Last Post: 07-09-2015, 11:41 AM
  2. BT keyboard that actually works with the GNote 10.1 2014
    By pcbtmr in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-23-2014, 04:41 PM
  3. Replies: 3
    Last Post: 01-14-2014, 06:21 AM
  4. Galaxy S4 - need help with Hyperdrive
    By Adrian Rangel in forum Samsung Galaxy S4
    Last Post: 01-13-2014, 10:39 PM
  5. want to do more with my s3!
    By Austin185 in forum AT&T Galaxy S3
    Last Post: 01-13-2014, 08:26 PM
