Results 1 to 3 of 3
    Default Galaxy S4 - Using camera from lock screen
    Hi,
    I would like to use the camera from the lock screen without entering my unlocking pattern.
    I know how to add shortcuts to apps in the lock screen when no password or unlocking pattern is defined.
    However, you can't add such apps when there is an unlocking pattern.
    This seems to be reasonable enough since you don't want anyone to access your phone without knowing the pattern.
    I would like to know if there is a way to exclude some apps such that I can access them immediately without entering the unlocking pattern.
    Specifically I would like to add the camera.
    My sister has an IPhone and it is possible to do it there.
    I would appreciate anyone's help in that.
    Thank you
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,691 Global Posts
    Carrier
    Stock 4.4 (KitKat)
    Default Re: Galaxy S4 - Using camera from lock screen
    Quote Originally Posted by shnadav View Post
    Hi,
    Thank you
    You may be able to achieve this with an App - stock may not be possible. You can try lock screen widgets from the Play Store and see if that works. Aside from that App, I'm not sure if anything else may work.
  3. #3
    How do you get the shortcuts to show up in the lockscreen settings?
  1. Galaxy S4 with 3 pin connector???
    By nonalis in forum Samsung Galaxy S4
    Last Post: 09-17-2016, 06:47 AM
  2. AT&T Galaxy Note 3 - gosms pro paid version
    By redrover69 in forum AT&T Samsung Galaxy Note 3
    Last Post: 02-04-2014, 09:41 AM
  3. Galaxy S3 - Touch not responding after firm tap on screen
    By cuddlypike in forum Samsung Galaxy S3 in Canada (Bell/Telus/Rogers)
    Last Post: 01-22-2014, 03:09 PM
  4. Bought a Samsung Galaxy S4 LTE last night and have already got a virus
    By poshbird87 in forum Android Security Talk
    Last Post: 01-21-2014, 09:54 AM
  5. Galaxy Note 10.1 (2014) BT keyboard issues
    By singh360 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-20-2014, 05:29 AM
