Results 1 to 2 of 2
    Default Problems with sim card
    So I replaced the screen on a galaxy s4.
    The screen worked and shortly after the phone started to tell me the sim was not connected and it had to restart. It would ten work for a while but ehn do the same thing.
    I then replaced the sim card tray.
    It is doing the exact same thing....what is going on?! Does anyone have any ideas on how to fix this??
  2. #2
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Default Re: Problems with sim card
    Quote Originally Posted by Luke Benge View Post
    It might be that a wire is loose/not connected. Did you yourself replace the screen or did another third party group do it?
  1. S Note Problems
    By bassbandit in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-25-2014, 09:04 AM
  2. Nexus 10 Tablet - Problems getting around flash player
    By stepaul8 in forum Google Nexus 10 Tablet
    Last Post: 01-23-2014, 04:32 PM
  3. GPS problems.
    By Foxhound221 in forum HTC Vivid
    Last Post: 01-20-2014, 11:20 AM
  4. Brightness setting-problem
    By capsfloyd in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-20-2014, 10:19 AM
  5. Galaxy Note 10.1: Flashed ROM now having problems when booted.
    By johnnie 65 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-19-2014, 11:00 PM
