1. Aussrh420's Avatar
    Hello! I recently purchased a Samsung galaxy s4 on Verizon wireless. I am pretty new to the Android world and I have been having a lot of trouble with my battery life. It seems to drain about a % every minutes or so, even when there are no apps running and the screen is set to the lowest brightness. I have to constantly connect it to the charger and it is becoming very frustrating! Anyone else experience this issue!?
    01-23-2014 10:52 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! First, remove the battery, lay it flat on a smooth surface, and see if it spins freely. If so, the battery's bad (even though it's brand new, it can still be defective).
    If the battery seems ok physically, then review this guide and see if the tips help: [Guide] Battery Saving Tips
    01-23-2014 11:52 AM
  1. Web browsing on Nexus 7 2nd generation battery drain !!
    By iDoc86 in forum Google Nexus 7 Tablet (2013)
    Last Post: 02-07-2014, 06:02 PM
  2. Can't stream media on S4 after 4.3 update?
    By thegeekkid in forum Samsung Galaxy S4
    Last Post: 01-24-2014, 11:48 AM
  3. Messaging app that uses data AND my number...
    By Effenhimer in forum Verizon Galaxy S III
    Last Post: 01-24-2014, 12:08 AM
  4. GS4 Charger Port Problems
    By catzmeow4me23 in forum General Help and How To
    Last Post: 01-23-2014, 05:35 PM
  5. Replies: 4
    Last Post: 01-23-2014, 01:46 PM
