1. stapler33's Avatar
    ever since i updated the firmware on my rooted s4 the wifi key recovery app has been showing the wrong wifi passwords even though the phone is still connecting to the wifi networks . ive tried deleting the networks and connecting again but the problem still remains. i have also gone into the data/misc/wifi folder on my root browser and the wpa_supplicant file is showing the passwords incorrectly too. i was wondering does anyone know what has caused this problem and is there a way to fix it. i have tried deleting the wpa_supplicant file and re connecting to the networks. and i have also tried different wifi password recovery apps and the problem still remains. thanks in advance for any help
    01-25-2014 04:27 AM
  2. mhinc's Avatar
    You should just be able to "FORGET" the wifi network and then re enter the password. I am guessing that's what you meant when you said you deleted the network? Not sure why that wouldn't work, but then again I don't root, and that's the obvious issue,so not sure
    01-25-2014 07:48 PM
  3. yasir gorsi's Avatar
    09-03-2016 12:55 PM
  4. yasir gorsi's Avatar
    hi I'm also have same problem Im root my galaxy note 4 but but WiFi key show not correctly any body help????
    09-03-2016 12:57 PM
  1. Phone keeps turning on and off while on charge with a single vibration
    By Hawkhe in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-21-2015, 04:26 AM
  2. My S3 Mini won't turn on
    By johncowb in forum Samsung Galaxy S3 Mini
    Last Post: 01-31-2014, 11:56 PM
  3. Replies: 2
    Last Post: 01-25-2014, 06:41 AM
