1. jsbcarman's Avatar
    In developer options I turn off animation and phone is fast.but when I use camera the settings change. How can I make them stay at zero?
    01-25-2014 12:00 PM
  2. mhinc's Avatar
    I have never heard of, or experienced the animations changing on their own, via using the camera or anything else for that matter.
    Mine have been at 0 and stayed at 0 since I altered them when I got my phone in June. So I am not sure what you are doing to cause it
    but I am guessing it's got to be an app or possibly form rooting if you did so?
    01-25-2014 07:47 PM
  3. HPferoxCraft's Avatar
    Yes, the transition animation sets itself back to 1 after using the camera. Idk why. Think it's a 4.3 bug.
    Sent from my SPH-L720 using AC Forums mobile app
    01-25-2014 09:10 PM
  4. Sanjay Chandra's Avatar
    Yes , Its 4.3 bug which was also present on Note III at first but Samsung fixed it on Note and later pushed a stability update to S4 to fix that issue.
    01-26-2014 06:21 AM
  5. jsbcarman's Avatar
    I wish I'd get my stability update. Damn! I hate animations makes phone very laggy.
    01-27-2014 08:17 PM
  6. jsbcarman's Avatar
    According to my phone it's already up to date. yet it still has this problem.. Very weird
    01-28-2014 07:36 AM
  7. warpdrive's Avatar
    I know that you might hate to hear this, but try a factory reset. It should solve your problem if you are fully updated.
    01-28-2014 02:01 PM
  1. Replace AccuWeather, set degrees to F (not C)?
    By BlackAudiA5 in forum General Help and How To
    Last Post: 04-01-2017, 03:03 PM
  2. Tiles on settings
    By smartiekins in forum Moto G (2013)
    Last Post: 01-25-2014, 09:35 AM
  3. Best Franco Kernal Settings
    By 1210saad in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 01-24-2014, 06:13 PM
  4. App/tweak/setting to prevent shut off??
    By took2089 in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-23-2014, 11:00 AM
  5. Can someone post the end-all be-all guide to AT&T 4G LTE APN Settings?
    By arbour0713 in forum HTC One Rooting, ROMs & Hacks
    Last Post: 01-23-2014, 08:52 AM
