Results 1 to 2 of 2
    Austin Alexander's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default S4 stuck on AT&T firmware screen
    Hello community so i tried to install custom clockword recovery on my Galaxy S4 and when I booted it up I got a message with a yellow triangle that said "Firmware not authorized by AT&T" and i tried to restore back to 4.2.2 via Odin but i kept getting an error message due to the lower firmware, I tried doing an emergency firmware recover on kies and that didnt work either does anyone have any suggestions ive been trying to fix this for nearly 5 hours and no luck whatsoever
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,762 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: S4 stuck on AT&T firmware screen
    Quote Originally Posted by Austin Alexander View Post
    Welcome to the forums! So Odin doesn't let you restore the device? That's odd, I never heard of that type of issue or error. Make sure you are in download mode and try a different USB port on the computer. Run Odin again and try restoring the file. You might also want to redownload the file or try another and see if that yields different results.
  1. Verizon Galaxy S3 on AT&T 3g/4g
    By Karmakaidan in forum Verizon Galaxy S3
    Last Post: 08-29-2015, 01:56 PM
  2. Flash Player on Rooted 4.4.2
    By 1210saad in forum Android 4.4 KitKat
    Last Post: 04-30-2014, 01:14 AM
  3. Can't remove apps at bottom of screen
    By Rilla1 in forum Samsung Galaxy Tab 2 10.1
    Last Post: 02-05-2014, 11:56 PM
  4. Photo size on Display
    By nrthwds in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-27-2014, 10:31 PM
  5. samsung s4 mini blacking out
    By cezza180 in forum Samsung Galaxy S4 Mini
    Last Post: 01-26-2014, 08:56 PM
