Results 1 to 3 of 3
    dgr8h's Avatar
    Posts
    Global Posts
    10 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Battery Power Drainage
    Hey everyone so I woke up at 7am with my phone fully charged 100% everything is off only the power saving and sound is on even the screen brightness is set to its lowest all apps are fully closed it is now 8:51am and I have 68% battery power with no usage apart from checking the time on my phone O.O never had a battery for a phone drain so fast in my life ..will be going work and when I return ill update you all on what battery percentage is left ..Battery doctor is showing ram used:793mb free:1gb what I want to know is if this a 4.3 issue or battery issue? ordered a new battery online just in case
  2. #2
    electricpete's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery Power Drainage
    Look at the built in battery stats to help figure out what is using battery. Get gsam for more detailed stats.
    I don't know what battery doctor is...does it break down the usage?
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    dgr8h likes this.
    dgr8h's Avatar
    Posts
    Global Posts
    10 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just got home with 48% battery to spare found out the problem the micro sd card was draining the battery like crazy not sure why so I took it out will need to get another to test it out hopefully the new one wont drain much.
  1. HTC One battery life
    By Tim98TA in forum HTC One M7
    Last Post: 03-26-2014, 03:26 PM
  2. Note 3: Replacement batteries
    By hokie_prof in forum Verizon Samsung Galaxy Note 3
    Last Post: 02-17-2014, 09:58 PM
  3. Deep Sleep Battery Saver
    By kanesmith41 in forum General News & Discussion
    Last Post: 01-28-2014, 04:53 PM
  4. Hidden battery power
    By Mike Armitage in forum Samsung Galaxy S3
    Last Post: 01-28-2014, 02:03 PM
  5. Google search draining the battery.
    By Octaviannn in forum Google Nexus 4
    Last Post: 01-27-2014, 07:38 AM
