1. melmc1403's Avatar
    Hey!
    My S4 had an update yesterday (think it's maybe for stability or something as it's still on 4.3). Ever since, my battery has been draining really fast. Anyone else on the same boat?
    Thanks
    Mel
    Sent from my GT-I9505 using AC Forums mobile app
    01-27-2014 06:26 AM
  2. VDub2174's Avatar
    Were you able to see if anything was causing the battery drain? I noticed that every once in a while that Google Play Services kills my battery.
    01-27-2014 06:47 AM
  3. Jordnoed's Avatar
    If you dont use it, turn of the 4G/LTE.
    Mine was turned on after the latest update.
    01-27-2014 06:54 AM
  4. melmc1403's Avatar
    I checked the battery status and there's nothing outta the ordinary draining it but since this update it's draining really quickly. Help! x
    01-27-2014 04:02 PM
  5. warrior6's Avatar
    my s4 went from 100% to 1% in 8 hours, most of that time the phone was in flight mode as i knew i was in a poor signal area. Any ideas? nothing obvious on the battery use page
    01-30-2014 03:01 PM
  1. HTC One battery life
    By Tim98TA in forum HTC One M7
    Last Post: 03-26-2014, 02:26 PM
  2. Note 3: Replacement batteries
    By hokie_prof in forum Verizon Samsung Galaxy Note 3
    Last Post: 02-17-2014, 08:58 PM
  3. Hidden battery power
    By Mike Armitage in forum Samsung Galaxy S3
    Last Post: 01-28-2014, 01:03 PM
  4. Battery Power Drainage
    By dgr8h in forum Samsung Galaxy S4
    Last Post: 01-27-2014, 11:21 AM
  5. Google search draining the battery.
    By Octaviannn in forum Google Nexus 4
    Last Post: 01-27-2014, 06:38 AM
