Results 1 to 6 of 6
    kapoorudit's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Erratic Locking Issue
    Hi,
    I have an unlocked Galaxy S4, the lock time is set as 30 mins. The issue I am facing is that when I initiate any call and for some reason the call drops, my phone goes to the lock screen and I need to unlock this. Also when I am connected to my car Bluetooth any time i disconnect a call using my car bluetooth the phone locks.
    I am running Android 4.3 and my phone is GT-I9500 with Samsung touchwhiz.
    Thanks in advance for any help.
  2. #2
    FutureKix's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Erratic Locking Issue
    I believe the phone is supposed to lock everytime a call is ended without touching the phone. So a dropped call, or a call ended by the other person, or a call ended by a button on your bluetooth headset should lock the screen automatically. It's not a glitch, it's a security measure. This is to prevent someone from getting into your phone, like if you let a stranger barrow it to make a call, or to prevent someone from using your phone if they find it while you're using a separate bluetooth headset.
    Now, if you're having an issue with calls dropping, then that's separate, but as far as the screen locking, I do believe that is intended, not a glitch or error.
    kapoorudit's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the reply. This issue also exists when not using bluetooth. As long as the person at other end of the call disconnects 1st or the call drops the phone locks. I also updated my OS to kitkat and this issue even persists post update.
  4. #4
    sasha's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by kapoorudit View Post
    I do believe it's a security feature, mine behaves the same way.
    kapoorudit's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by sasha View Post
    I can understand there can be a security issue when using with a bluetooth headset. However when not using bluetooth if the other person disconnects before me the phone should not lock. Is there a way to turn this off whilst still keeping the 30min lock schedule?
  6. #6
    sasha's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Only way I've found is to, unlock the phone during the call, and it will remained unlocked once the call has ended.
  1. G Pad 8.3: Is the brightness that much of an issue?
    By Emac4444 in forum LG G Pad 8.3
    Last Post: 03-06-2014, 01:13 AM
  2. another sd card issue
    By Chinookman in forum Samsung Galaxy S4
    Last Post: 02-01-2014, 11:56 PM
  3. I'm locked out of GT-5570 (S3 Mini)
    By Fototaker Sf in forum Samsung Galaxy S3 Mini
    Last Post: 01-26-2014, 05:51 PM
  4. MMS issues
    By snomanjj in forum AT&T LG G2
    Last Post: 01-26-2014, 05:50 PM
