Results 1 to 2 of 2
    Default Calls to my S4 going straight to voicemail, text messages only coming through when I'm on the phone
    My S4 has been acting up for about a month now. It began when I unlocked my phone by purchasing an unlock code from my carrier (Fido, in Canada). Beginning then, my mobile data has been shutting off on a regular basis.
    Today, I figured I'd try resetting the phone to factory settings. Partially to fix this, and partially because all of the Samsung apps were taking up too much space on my phone. Now, my calls incoming calls go straight to voicemail, and my incoming text messages only get delivered while I'm on an outgoing call. Can anyone explain what might be going on? I called Tech Support but all they could recommend is that I go to their store and have them try and fix the phone in person.
    Thanks!
  2. Thread Author  Thread Author    #2
    Default Re: Calls to my S4 going straight to voicemail, text messages only coming through when I'm on the ph
    In case anyone stumbles across this later, I thought I'd share my solution.
    It seems that the issue was related to my phone connecting to the LTE network. The solution was to go to Settings=>Connections=>More networks=>Mobile networks=>Network mode and then choose "GSM/WCDMA".
    I found this thread that explains it.
    Hopefully you aren't having this problem, but if you are, following these steps seems to solve it.
  1. Replies: 2
    Last Post: 02-04-2014, 09:00 PM
  2. Group Messaging
    By blg923 in forum HTC One
    Last Post: 01-29-2014, 02:33 PM
  3. Avia error message
    By STLYoungblood in forum Google Chromecast
    Last Post: 01-28-2014, 07:47 PM
  4. No Wifi after updating to Stock on Galaxy Note 3
    By Ken Simon in forum Samsung Galaxy Note 3 in Canada (Bell/Rogers/Telus)
    Last Post: 01-28-2014, 05:54 AM
  5. Backspace in the middle of a sentence copies and replaces random text
    By clearweave in forum Samsung Galaxy Note 10.1
    Last Post: 01-27-2014, 08:27 PM
B
