1. walesser's Avatar
    Ok so I dropped it like 11-12 hours before. When I dropped it I IMMEDIATELY pulled it out, it was in like 1 sec or something... When I pulled it out it all worked well, I dried it with a towel and all. Sounds was OK, screen was OK, everything was perfect, as it was before I dropped it. But when I tried to open the camera 1 hour ago, it was very blurry... Both front and back cameras... So I took out the battery, sim and microSD card, and now I'm here.
    Now what should I do? What's my best bet? I heard drying with a hoover (because hair dryers push the water inside, while hoovers pull it out), putting it into a white rice for 2-3 days... Are they work for cameras, or is my camera dead? Is it too late?
    Can I have it repaired or something? My S4 is %100 original and yes, I do have guarantee. I heard that they were waterproof though...
    Please help, any comment is appreciated.
    note: I dropped into the toilet if that makes any difference, lol.
    01-28-2014 10:06 AM
  2. Almeuit's Avatar
    You can try the rice for a few days but you should of done that right away.. The towel only dried the outside.
    Any time a phone goes in water it should be shut down, battery and stuff taken out, and then let it sit in rice for 3 days or so.
    Sent from my T-Mobile Note 3 using AC Forums.
    walesser likes this.
    01-28-2014 10:37 AM
  3. Almeuit's Avatar
    And only the S4 "Active" is water "resistant". The normal S4 is not water anything.
    01-28-2014 10:38 AM
  4. Exze_S4's Avatar
    I put a bb on rice for a few days and dried very well, if u ask me i think i do the same whit the s4 but try to remove not only the battery try to remove the case for a better drying. Or u can carefuly try to dry the lens whit a swab
    Enviado desde mi Zapatofono GTi9500 con Tapatalk
    01-28-2014 10:40 AM
  5. walesser's Avatar
    Thanks for the reply. You think it's too late now?
    Everything is OK but the camera though...
    Thanks for the reply, but I don't want to mess up my S4 any further man, does it work if I leave it with only the battery, sim and microSD is removed?
    01-28-2014 11:11 AM
  6. Exze_S4's Avatar
    Well u can try, but i think the plastic around the camera wont let the rice absorve all the remain water or humidity, look for any video on youtube that teaches you how disarm youre phone, i change the usb plate of a s2 that i have and the glass and no s2 was harm..
    01-28-2014 11:20 AM
  7. Ava Amurao's Avatar
    hey i have the same issue right now. were u able to fix it? can u tell me what did u do?,
    06-12-2014 10:12 PM
  8. sipirtz's Avatar
    i dropped mine into the toilet yesterday with all the' stuff ' in it. took it out rinsed it, towel dried it, the charger didn't work ( message displayed the usb port is connected but it wasn't, my kid suggested the rice method but i had no 48 hrs or so , and i switched my stove on and put my phone above it for 5x 1minutes and voila! its working good again. i have an otterbox for 100 bucks tho
    06-14-2014 08:39 AM
  9. lilmomma843's Avatar
    I dropped my note 2 in the pool..I immediately snatched it out n took the phone apart..I put the pieces in a bag of rice for a day then put it back together. The screen is still black but the bottom lights work.. Any suggestions?
    06-19-2014 09:47 AM
  10. Jade Hunter's Avatar
    Hi honey. Same thing happened to mine. I let mine sit in the sun while it being in rice BC my camera did the same and it turned out fine
    03-10-2015 01:44 PM
  11. Deb Gamespage's Avatar
    Mine fell in a pond yesterday, and the camera was blurry too. I put it in a bag of rice overnight and it cleared it up. Everything works on mine now except the phone, I can't hear anyone, and they can't hear me, altho the speaker is working. I'm hoping another day in rice will help this!!
    04-09-2015 09:47 AM
  12. Inola Olds's Avatar
    04-17-2015 10:38 PM
  13. Mary Wright3's Avatar
    04-23-2016 03:23 AM
  1. Help with my Samsung Galaxy 4G
    By Dawn Perkins in forum Samsung Galaxy S4
    Last Post: 01-28-2014, 10:42 AM
  2. Replies: 1
    Last Post: 01-28-2014, 09:36 AM
  3. Birthdays being changed after I entered them into my contacts?
    By iznot in forum Samsung Galaxy S4 Mini
    Last Post: 01-28-2014, 08:49 AM
  4. How to Check in Mobile Android OS is upgrade-able or not ?
    By meashish in forum Android 4.4 KitKat
    Last Post: 01-28-2014, 08:05 AM
  5. update samsung galaxy s2 to 4.3 from 4.1.2
    By shilpa gupta in forum Samsung Galaxy S II
    Last Post: 01-28-2014, 07:58 AM
