Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By Almeuit
  • 1 Post By Almeuit
  • 1 Post By Exze_S4
    Default Dropped my Samsung Galaxy S4 in water, camera won't work...
    Ok so I dropped it like 11-12 hours before. When I dropped it I IMMEDIATELY pulled it out, it was in like 1 sec or something... When I pulled it out it all worked well, I dried it with a towel and all. Sounds was OK, screen was OK, everything was perfect, as it was before I dropped it. But when I tried to open the camera 1 hour ago, it was very blurry... Both front and back cameras... So I took out the battery, sim and microSD card, and now I'm here.
    Now what should I do? What's my best bet? I heard drying with a hoover (because hair dryers push the water inside, while hoovers pull it out), putting it into a white rice for 2-3 days... Are they work for cameras, or is my camera dead? Is it too late?
    Can I have it repaired or something? My S4 is %100 original and yes, I do have guarantee. I heard that they were waterproof though...
    Please help, any comment is appreciated.
    note: I dropped into the toilet if that makes any difference, lol.
  2. #2
    Default Re: Dropped my Samsung Galaxy S4 in water, camera won't work...
    You can try the rice for a few days but you should of done that right away.. The towel only dried the outside.
    Any time a phone goes in water it should be shut down, battery and stuff taken out, and then let it sit in rice for 3 days or so.
    Sent from my T-Mobile Note 3 using AC Forums.
    Thanked by:
    walesser likes this.
  3. #3
    And only the S4 "Active" is water "resistant". The normal S4 is not water anything.
    Thanked by:
  4. #4
    Exze_S4's Avatar
    Posts
    Global Posts
    21 Global Posts
    I put a bb on rice for a few days and dried very well, if u ask me i think i do the same whit the s4 but try to remove not only the battery try to remove the case for a better drying. Or u can carefuly try to dry the lens whit a swab
    Enviado desde mi Zapatofono GTi9500 con Tapatalk
    Thanked by:
    Quote Originally Posted by Almeuit View Post
    Thanks for the reply. You think it's too late now?
    Everything is OK but the camera though...
    Quote Originally Posted by Exze_S4 View Post
    Thanks for the reply, but I don't want to mess up my S4 any further man, does it work if I leave it with only the battery, sim and microSD is removed?
  6. #6
    Exze_S4's Avatar
    Posts
    Global Posts
    21 Global Posts
    Well u can try, but i think the plastic around the camera wont let the rice absorve all the remain water or humidity, look for any video on youtube that teaches you how disarm youre phone, i change the usb plate of a s2 that i have and the glass and no s2 was harm..
  7. #7
    hey i have the same issue right now. were u able to fix it? can u tell me what did u do?,
  8. #8
    i dropped mine into the toilet yesterday with all the' stuff ' in it. took it out rinsed it, towel dried it, the charger didn't work ( message displayed the usb port is connected but it wasn't, my kid suggested the rice method but i had no 48 hrs or so , and i switched my stove on and put my phone above it for 5x 1minutes and voila! its working good again. i have an otterbox for 100 bucks tho
  9. #9
    I dropped my note 2 in the pool..I immediately snatched it out n took the phone apart..I put the pieces in a bag of rice for a day then put it back together. The screen is still black but the bottom lights work.. Any suggestions?
  1. Help with my Samsung Galaxy 4G
    By Dawn Perkins in forum Samsung Galaxy S4
    Last Post: 01-28-2014, 10:42 AM
  2. Replies: 1
    Last Post: 01-28-2014, 09:36 AM
  3. Birthdays being changed after I entered them into my contacts?
    By iznot in forum Samsung Galaxy S4 Mini
    Last Post: 01-28-2014, 08:49 AM
  4. How to Check in Mobile Android OS is upgrade-able or not ?
    By meashish in forum Android 4.4 KitKat
    Last Post: 01-28-2014, 08:05 AM
  5. update samsung galaxy s2 to 4.3 from 4.1.2
    By shilpa gupta in forum Samsung Galaxy S II
    Last Post: 01-28-2014, 07:58 AM
