1. NavyWifeHaines's Avatar
    So I've gone about everything in my phone to try to get my old settings back to the way I had them. I recently had to get a replacement phone. The particular setting that is frustrating me is when you make a call and the screen will go black so you don't accidentally put it on speaker or mute it...but when you look at it again it will light back up. This doesn't require pressing any buttons....just when you put the phone up to your ear it the screen will lock and when to take it away from your ear it will light back up. Please help lol getting frustrated....no bashing please :-)
    01-29-2014 01:09 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I don't have an S4, but I recall another post showing an option in the Call Settings to turn the proximity sensor on or off. Open your Dialer, press the Menu button, then look in the Call Settings for that option.
    01-29-2014 01:13 PM
  3. STSVA's Avatar
    Settings - My device - Call settings - Turn off screen during calls (check the box by this one)
    01-30-2014 07:12 AM
  1. s pen won't write on one bit of screen above home button
    By nb22 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-05-2016, 04:23 AM
  2. Volume Control App with Scheduling, Lockout and Override
    By trd 4rnr in forum Samsung Galaxy S4
    Last Post: 07-18-2014, 06:14 PM
  3. dropbox help!!
    By mohnisingh in forum Samsung Galaxy S II
    Last Post: 01-31-2014, 10:06 AM
  4. need for speed most wanted
    By Del Wright in forum Android Apps
    Last Post: 01-29-2014, 11:57 AM
  5. dropbox help!!
    By mohnisingh in forum Introductions
    Last Post: 01-29-2014, 11:14 AM
