Results 1 to 13 of 13
    WXavierM's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default S4 Front Facing Camera problem
    Every time I try to use the front facing camera with a filter or different frame it becomes really really dark. Is that normal or is there something wrong with it?
  2. #2
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: S4 Front Facing Camera problem
    Quote Originally Posted by WXavierM View Post
    Well, i think the problem is with the light if you are sure that there is enough exposure to light then i think that there is some problem with the camera !!! Would advise you better if you uploaded some screen shots of it "If that's possible for you!! "
  3. #3
    mhinc's Avatar
    Posts
    Global Posts
    1,785 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think the first issue is, the front facing camera on the S4 is only 2 MP, no flash, no auto focus. Where as the primary camera is 13 MP, 4128 x 3096 pixels, autofocus, LED flash.
    So unless you are in PERFECT lighting, and even if you have good lighting, you are usually going to get a way lower quality, grainy, darker image.
    So to answer your question, no there is nothing wrong, it's a crappy camera Do what you have to to take your selfies on the primary
  4. #4
    andgy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the same problem and it is not because there is no flash on the front facing camera. When i am selecting the filter I'd like to use, there is a preview of what it would look like on the main screen (which would have perfect lighting). However, once I go to select the filter, the main screen would turn VERY dark and my face would no longer be visible. Just an outline of it. This is surely a glitch and not a problem due to improper lighting of the room. Anyone else have this problem??
  5. #5
    Destiny Taylor's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having the same issue. I try turning on every light in my room and it still would be dark. I thought it was something wrong with my phone.
  6. #6
    mhinc's Avatar
    Posts
    Global Posts
    1,785 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by andgy View Post
    Are you using 3rd party software when applying filters and such?
  7. #7
    andgy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Not at all. I'm using the filters that came stocked with the phone
  8. #8
    mhinc's Avatar
    Posts
    Global Posts
    1,785 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So the picture is fine, until the filter is applied then...
    Sounds like an software issue, not a camera issue.
  9. #9
    Aatir Salamat's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did you figure out how to fix it?
  10. #10
    Asteraceae's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    this is not an issue with the lighting. It's a glitch and I have experimented what causes it. It seems to occur most of the time but I only came up with one thing the surely causes it:
    If you're using a filter and you press back to minimize the camera and then you open it again.
    But I did come up with two solutions. Either should work
    Solutions:
    A. with a darkened filter On, press home button to minimize the camera and click the camera again to open it, it should revert back to normal.
    alternatively,
    B. with the darkened filter on, click the shortcut to gallery on the top left corner and then press back again. (Will not work if you're not using a filter when you click the gallery)
    I am a normal user and have no idea how these things work. I hope you guys can figure out what really causes it but that is how I fixed mine...
    This only seems to affect some S4s since I don't see much stuff about it when I google it.
    (mine supposedly made in vietnam (in the box) or UAE which is shown in my About Device.)
    Shamimaa xx likes this.
  11. #11
    ghost_313's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Can someone help me, I just bought my phone from eBay a at s4 unlocked almost brand new everything about it seemed perfect however I just noticed recently when I am using the front facing camera with the effects/filters it turns dark like very dark and but when I put it in no effect it seems fine. Its not due to the lighting or anything, I think its a software issue so how would I fix it ? Or can anyone tell me how to fix it? Also could it be because its still on android 4.4.1 like if it updated to 5.0.1 lollipop would the camera issue be fixed ?
  12. #12
    Ihaveasamsungs4's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah same thing been happening to me lately, thats why i downloaded snapchat, cuz i couldnt use my fav filter cuz i turned a deep blue....i feel u bro...i hink it may be cuz of updates? Maybe we need new phones..
  13. #13
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Same happens to me...i think we should ask people at JB Hi Fi see if they know why its being gay
  1. problem with a root
    By deaddeciple in forum LG Optimus G
    Last Post: 03-04-2014, 07:19 PM
  2. Sms stock app problem
    By AlexiosS3 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-31-2014, 11:13 AM
  3. Note 3 camera -- takes some getting used to
    By deludel in forum Samsung Galaxy Note 3
    Last Post: 01-29-2014, 09:23 PM
  4. Battery Problem
    By DaviPeixoto in forum Moto X (2013)
    Last Post: 01-29-2014, 05:54 PM
  5. Wifi hotspot problem
    By Totalgridlockman in forum Samsung Galaxy Note 2
    Last Post: 01-29-2014, 09:34 AM
