Results 1 to 1 of 1
    africano's Avatar
    Posts
    Global Posts
    16 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Problem with Menu screen??
    Hi guys,
    I dont know if there is a problem with my menu screen or a glitch or something or if its normal....
    But it look off for some reason......Can you have a look and let me know of its normal?
    Attaching an image. Main issue is: Is that bar at the top where you see MENU and WIDGETS across the top of the screen, is that normal?
    Thanks!
    EDIT: cant upload image? - Main issue is when I enter the menu by pressing the Menu button on my S4 home screen it takes me to the menu but at the top I can see MENU and WIDGETS across the top , above my icons. Is that normal?
    Thanks!
  1. Anyone can edit my lock screen?
    By Daniel MacDonald1 in forum General Help and How To
    Last Post: 02-03-2014, 07:45 PM
  2. Another problem.
    By Jr Lagos in forum Introductions
    Last Post: 02-02-2014, 05:18 AM
  3. screen and widgets
    By singh360 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 01-31-2014, 10:39 PM
  4. Temp never updates on lock screen
    By strycat in forum Verizon Droid DNA
    Last Post: 01-30-2014, 02:28 PM
  5. How to connect S4 with a signal booster
    By Ahmed Qasim in forum Samsung Galaxy S4
    Last Post: 01-30-2014, 02:07 PM
