Results 1 to 3 of 3
    donnadlc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Solution to S4 screen dimming issue
    At least for me, this is a golden solution and I am psyched! On another forum a user mentioned an app named "Caffeine" by Syntaxa (it's on Play). I checked it out and voila - it works like a charm!
    "Caffeine is a tiny easy to use application which prevents your phone from going to sleep, lock or dim the screen.
    You can toggle it manually or let it automatically activate only when the device is connected to AC Adapter and/or PC."
    My issue is that I want my screen to remain at a preset level of brightness with no dimming when I have it plugged in, which is at my desk or in the car. Caffeine allows you to set this option and handles it beautifully. After days of searching for a solution (I have changed the developer option to Stay Awake, but this does not prevent dimming), Caffeine is it!! I hope this might help someone else.
  2. #2
    argold's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Solution to S4 screen dimming issue
    The Google Play blurb for Caffeine says "Support for Android 1.5 - 2.3".
    donnadlc's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I noticed that. However, other reviewers were using the S4 and posting rave reviews. Also, Play said it was compatible. And so far, it's working just as I want.
  1. How to Get Android 4.4 KitKat StatusBar [No Root] [FREE]
    By jayboiandroid in forum General Help and How To
    Last Post: 02-01-2014, 12:16 AM
  2. Unable to change web home page
    By pnm999 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 01-31-2014, 08:25 AM
  3. How to enable Desktop notifications without Wifi?
    By Zakariyya Gardee in forum General News & Discussion
    Last Post: 01-31-2014, 02:39 AM
  4. How to enable Desktop notifications without Wifi?
    By Zakariyya Gardee in forum General Help and How To
    Last Post: 01-31-2014, 02:04 AM
  5. "Messages isn't responding. Do you want to close?"
    By tommyg530 in forum Verizon Samsung Galaxy Note 3
    Last Post: 01-30-2014, 10:17 PM
