1. Larry Jewell1's Avatar
    How do u get my group contacts to use the assigned group ring tones, for some reason the default ring tone is the one used unless I have specifically assigned a ring tone to the individual
    contact. I never had this kind of trouble with my blackberry....
    02-01-2014 08:27 AM
  2. dimm0k's Avatar
    welcome fellow BlackBerry user! coming from the Bold 9930 myself and can't help but feel a bit overwhelmed with all the settings on an Android device. anyway, this is how I did it...
    go into Phone > Contacts > Groups
    go into the desired group or create a new one with the Menu button
    if you're creating a new group, it should let you choose a group ringtone, if using an already created group press the Menu button and choose 'Edit group' and you should see the option to select group ringtone, as well as add other contacts to this group
    02-01-2014 11:41 AM
  3. Larry Jewell1's Avatar
    Thanks for the reply.... That is exactly how I set it up, however for some reason the group ringtone is ignored and the default runtime is used
    02-03-2014 06:22 AM
  4. dimm0k's Avatar
    I can't find it on my device at the moment, but I believe somewhere in the Applications Manager there's a module for ringtones that would allow you to clear the cache for ringtones... just stumbled upon it recently. If I find it, I'll post back.
    02-03-2014 03:24 PM
  1. adding to favourite contacts
    By flannob in forum Samsung Galaxy S4 Mini
    Last Post: 02-22-2014, 04:53 PM
  2. I've converted from Blackberry and i am DELIGHTED
    By hal9550 in forum Introductions
    Last Post: 02-14-2014, 10:48 PM
  3. Anybody have the S view cover and wireless s view cover?
    By thegame161 in forum Samsung Galaxy Note 3
    Last Post: 02-05-2014, 10:21 AM
  4. Note 3: Device status custom and cannot update
    By Anil kumar 20 in forum Samsung Galaxy Note 3
    Last Post: 02-02-2014, 12:31 AM
  5. Deleting Phone Contacts but NOT Google Account Contacts
    By nixgnzlz in forum General Help and How To
    Last Post: 02-01-2014, 11:27 AM
