I NEED HELP- GS4 wont turn on and is continuously vibrating
Garrett_Clark
I just drained the battery on my galaxy s 4 and when i plugged it back into the charger, it refused to turn back on and vibrates about every 4 seconds. I've already taken the battery out and held down every combination of buttons but nothing is working. the most i get is when i hold the power button the startup screen appears for a few seconds and then goes away. I desperately need help, and would be grateful for any advice. also if i leave it plugged in for a while a grey battery bar appears for a few moments but then goes away.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Welcome to the forums.
If you were to pull the battery for a few minutes, then reinsert, plug it in and not try to turn it on, what does it do?
Kevin OQuinn
AC Team Emeritus
May 17, 2010
9,267
496
Leave it plugged in to the Samsung provided charger overnight and see what happens. If you drained the battery to a super low point it might need to "wake up" for lack of a better term. Another potential solution would be to buy the desktop battery charger for ~$30 and charge the battery outside of the phone. That would be the last thing I would do, though. No need to spend money if you don't have to.
EmanPlayback
I had the exact same issue last night and it seems like the phone will not turn on because I took out the battery, placed it back inside and charged it over night and now it won't even vibrate and the grey battery bar does not appear. Let me know the outcome of your situation, cheers.
totosch
I had the same problem (after accidentaly sinking my phone for 10 min :-D). You can "force" the charge by connecting the phone to the computer via USB cable for few minutes and then charging the phone with the original Samsung charger. As I red, there is an known issue with the micro USB port on galaxy S4. I hope this method will work for you.
kemberley1
