1. Soniku's Avatar
    So while driving this past Thursday, I was using my GPS, and streaming music on Spotify to my car radio via Bluetooth. My phone randomly shut off (screen just went black, no warning). I turned it back on, and it turned off within seconds of getting into the OS. I turned it back again, and same deal. Then I pulled the battery, and put it back in; same problem. I decided that maybe it was a bad battery, and I put a different battery in (I own 3 official batteries), and it worked fine.
    Later on that day, I put the "bad" battery back in my phone, thinking that it might've over-heated, and it eventually displayed the same symptoms again while talking on the phone, and using a bluetooth headset (the GPS was off if anyone cares). I decided to give up on the battery, and just marked it as bad, and didn't use it again.
    Today I was using a different battery, and the exact same thing happened while using the GPS, and listening to a locally saved podcast, and using a Bluetooth headset. I fixed the problem by putting the "bad" battery back in the phone (the other good battery was already dead), so now I don't know what to think.
    I guess the battery connector on the phone is most likely the problem? I'm probably going to just RMA the phone, but I'm hoping that maybe someone has an idea before I do.
    All help is appreciated!
    Thanks!
    Edit: I forgot to mention that I noticed the phone completely losing LTE/3G connectivity a split second before it shut off once, and it also seemed to be completely unresponsive during that same moment.
    Also this has happened both in and out of a case, so I don't think overheating is the problem.
    02-02-2014 03:32 AM
  1. "Unfortunately the camera has stopped working"...
    By Rockmesocks in forum Samsung Galaxy Gear
    Last Post: 12-09-2016, 02:28 AM
  2. Replies: 2
    Last Post: 02-09-2014, 09:07 AM
  3. Updates for Galaxy Note
    By kerry lee in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 02-02-2014, 09:15 AM
  4. I NEED HELP- GS4 wont turn on and is continuously vibrating
    By Garrett_Clark in forum Samsung Galaxy S4
    Last Post: 02-02-2014, 05:11 AM
  5. Flash galaxy nexus
    By Alton Smith1 in forum Sprint Nexus S 4G
    Last Post: 02-01-2014, 10:19 PM
