1. njohnv's Avatar
    the best sd card for samsung galaxy s4? trying to figure out if sandisk or the samsung sd card which one of them?
    02-07-2014 06:40 PM
  2. wizzrah's Avatar
    You should try Sandisk:
    32GB: Amazon.com : SanDisk Ultra 32 GB MicroSDHC C10/UHS1 Memory Card with Adapter (SDSDQU-032G-AFFP-A) : Micro Sd Cards : Electronics
    16GB:Amazon.com : SanDisk Ultra 32 GB MicroSDHC C10/UHS1 Memory Card with Adapter (SDSDQU-032G-AFFP-A) : Micro Sd Cards : Electronics
    64GB: Amazon.com : SanDisk Ultra 32 GB MicroSDHC C10/UHS1 Memory Card with Adapter (SDSDQU-032G-AFFP-A) : Micro Sd Cards : Electronics
    But if you are on a budget, there are cheaper SD Cards:
    Cheaper SD Cards
    I also listed Amazon just to give you an idea. You can look else where as well.
    02-07-2014 06:54 PM
  3. bugeyed's Avatar
    Check for threads about the S4 corrupting SD cards. Consensus is that Samsung cards are less likely to suffer this & maybe stay away from class 10 cards. There is no conclusive data, but people are having better luck with Samsung cards slower than class 10. .
    k
    bodum02 likes this.
    02-07-2014 09:10 PM
  4. Aesthete18's Avatar
    Don't get Kingmax, mine lasted for 6 months.
    02-08-2014 09:21 PM
  5. newS4owner's Avatar
    i have a 32 GB sandisk, no problems
    02-09-2014 01:57 AM
  6. Robnrbrtsn's Avatar
    You may want to stay at 32MB. Some people have had issues (me included) with 64MB cards. Occasionally I get an error message that my SD card was unexpectedly removed, then it reloads. I've tried a few fixes, even reformatted my card to FAT32 after backing up my data, but I still get the error now and then.
    02-10-2014 10:33 AM
  1. Sprint S4: Help with SuperSU not working on MK2 rooted!!!
    By DASHZNT in forum Sprint Samsung Galaxy S4
    Last Post: 02-08-2014, 11:51 AM
  2. Really annoyed, help!
    By Stefan Price in forum Samsung Galaxy S4
    Last Post: 02-08-2014, 05:43 AM
  3. Made me smile.
    By troshs in forum Samsung Galaxy S4
    Last Post: 02-07-2014, 10:40 PM
  4. Uhh... my n7 2013 screen just spiderweb cracked, digitizer borked, help?
    By darth android in forum Google Nexus 7 Tablet (2013)
    Last Post: 02-07-2014, 02:40 PM
  5. Galaxy s4 help Os system
    By Gordan Magniette in forum Samsung Galaxy S4
    Last Post: 02-07-2014, 01:05 PM
