1. separationx's Avatar
    I went to Chicago to be with my mom since I go to college in a different state but when I came back to Nashville, my 3G stopped working. I factory resetted, I made sure the mobile date was on along with the roaming but I still don't get 3G. Help???
    02-09-2014 08:37 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try going to Settings>Wireless & Networks>More, then Mobile Networks, then look at your Preferred Network Type. Make sure it is appropriate for your local network.
    02-09-2014 08:44 PM
  3. separationx's Avatar
    I looked at everything and then put my phone on airplane mode for a few seconds and turned it off and still nothing.
    02-09-2014 09:13 PM
  4. B. Diddy's Avatar
    Are you talking specifically about 3G (which is slower than 4G), or are you talking about mobile data in general? Is there no 4G available in your area?
    02-09-2014 09:16 PM
  5. separationx's Avatar
    All of it. Mobile data is on but not working. It was working fine last semester and in my mom's house but when I came back whereever I go it won't connect to the internet, send mms, anything.
    02-09-2014 09:28 PM
  6. B. Diddy's Avatar
    Is your wifi on? If it's on and connecting to your mom's network, that usually turns off mobile data automatically. And if your mom's wifi network is working poorly or not at all for some reason, then your phone won't get any internet connection.
    02-09-2014 09:46 PM
  7. separationx's Avatar
    I'm back in college so I'm not at my mom's anymore and I turned wifi off but I still don't get 3G or anything.
    02-09-2014 10:36 PM
  8. B. Diddy's Avatar
    I wonder if there's a problem with the mobile data radio itself, or the antenna. Since you mentioned already that you tried a factory data reset, the next step will probably be for you to bring the phone into a cellphone repair shop, or call Samsung if it's still under warranty.
    02-09-2014 10:48 PM
  9. separationx's Avatar
    I wonder if it's an AT&T thing or just an Android thing in general.
    02-09-2014 10:50 PM
  10. B. Diddy's Avatar
    I doubt it's an AT&T thing. You probably know other people on AT&T--ask them if they're having problems.
    02-09-2014 10:53 PM
  11. Stubbo's Avatar
    Mine does this intermittently
    Have you tried pulling the battery out for 30 seconds?
    I find the restart option on the phone doesn't fix this, but battery pull does (reminds me of my blackberry days!)
    02-10-2014 07:37 AM
  12. separationx's Avatar
    Yeah I did everything and still nothing.
    02-10-2014 01:34 PM
  13. Aufidious's Avatar
    10-23-2014 05:28 AM
  14. Aufidious's Avatar
    I had the same problem. I have just now gone into "SIM toolkit" witch i found in my apps and selected "get settings". Then followed the instructions givin. Took about 5 min. Now my mobile data works.
    10-23-2014 05:37 AM
  15. Aleksandar Kitanovic's Avatar
    Tray to maunali enter parameters for your operator!
    05-29-2015 05:09 AM
  1. Data Usage Cycle
    By Aalbie in forum Moto X (2013)
    Last Post: 02-09-2014, 09:46 PM
  2. Group messaging-Samsung Galaxy S4 with iPhones won't work?!
    By jaminicole in forum Samsung Galaxy S4
    Last Post: 02-09-2014, 08:35 PM
  3. Group messaging-Samsung Galaxy S4 with iPhones won't work?!
    By jaminicole in forum Rumored Devices Lounge
    Last Post: 02-09-2014, 08:34 PM
  4. If you have the Element Eclipse case...
    By LoveMyPhone in forum Samsung Galaxy S4
    Last Post: 02-09-2014, 07:42 PM
  5. Contacts won't pop up as I type them
    By M Bailey in forum Samsung Galaxy S4 Active
    Last Post: 02-09-2014, 06:02 PM
