1. bjromaine's Avatar
    I just upgraded my phone to a Galaxy S4. I would like to know if several apps, such as Google Maps, S4 Voice, etc will work over the Bluetooth in my 2013 car with the radio in the car playing?
    If it will not, is there an app that will help that?
    02-11-2014 08:17 AM
  2. Androidest's Avatar
    I think you should first try it and see whether it works like you expect it to in your car. But I am advised it will work just fine, otherwise if there arises a problem, then there's always a solution.Let me know.
    02-11-2014 09:52 AM
  3. bjromaine's Avatar
    That is the basis for my question. I have tried it and nothing comes over the radio if the radio is playing. I did not know if it was because the phone will not support it Or if the settings are incorrect
    02-11-2014 02:40 PM
  4. AshManMB's Avatar
    What kind of car do you have? a 2013 car may not support the necessary functions for bluetooth streaming.
    Does your car have a function for bluetoooth audio in the audio section of the radio?
    Are you trying to do it via the phone system bluetooth connection in the car?
    It may not support working on the phone system portion since that is used for phone call audio only.
    Some cars will have a seperate bluetooth audio connection in them.
    But if you have a standard aux in port that would allow you to connect a mini stereo cable to your phone's headset port for audio, but would not work via bluetooth audio.
    02-11-2014 04:35 PM
  5. Androidest's Avatar
    Then the problem is with the radio not the phone, I am not sure on how to work on the car bluetooth setting but it seems its bluetooth device is more advanced than your phones or the viceversa or its just some setting that you could change. The best you could do is get in touch with the radio manufacturer or your car technician(not mechanic). But, before you do so, try using a different phone and see whether it works. You could also get the radios manual and see whether you could work on the settings its probably something to do with the settings.
    02-12-2014 03:53 AM
  6. bjromaine's Avatar
    Ok I will try to address/answer all questions.
    First of all this is a Samsung Galaxy S4, purchased Saturday so it is up to date. The car is a 2013 Hyundai Santa Fe Sport 2.0 and it is completely bluetooth capable. I can stream music, the Assistant App works fine including interrupting the radio for "conversation". If I set the car radio mode to bluetooth audio all apps work fine. It is only when the radio is playing certain apps do not interrupt the radio.
    Yes it does as described above.
    Yes and most of the time it work flawlessly. Phone calls and the Assistant interrupt the radio and release it back to the radio.
    This works.
    My car has a separate setup for bluetooth and my phone is paired.
    I realize this and my car does have an aux port and it functions EXCEPT I cannot listen to radio.
    My prior phone and car, HTC Rezound and 2008 Veracruz worked just fine.
    02-12-2014 08:12 AM
  7. AshManMB's Avatar
    I know my S4 on 4.3 has some issues with bluetooth audio, where I cannot see track information from pandora anymore, but works fine in other aspects.
    I know on my car, unless I am bluetooth audio, I don't get any interruption on my car when listening to regular radio unless I am on the bluetooth audio function or if a call comes in.
    I am wondering if the phone and car being different than your previous ones is the issue here. different car, different phone, different functionality.
    02-18-2014 06:49 PM
  8. bjromaine's Avatar
    That may be the case and hence the reason for my original post. If it is known that there are bluetooth problems with S4 are there any apps that address it?
    But I do have 1 app that works with the bluetooth perfectly. It interrupts my car radio or anything else in the car. So if that is the case the units are compatible. It has to be the Google apps are lacking....
    02-19-2014 08:37 AM
  9. bjromaine's Avatar
    any possible solutions to this problem? It seems the S4 connectivity to my car's bluetooth is lacking......my prior phone, 3 years old, worked just fine with the same car.
    03-05-2014 01:48 PM
  10. bjromaine's Avatar
    I finally was successful in getting this to work.
    Here are the required steps with my car. I expect other cars will be similar.
    The problem is not with the phone nor the car. It is in setting up both.
    To receive calls, map navigation, S Voice, music (from Pandora, Tune-In, etc) you must have the phone set to Bluetooth Audio and/or Bluetooth Call.
    On the S4 (with KitKat) press settings/bluetooth. Connect to your car. then long press the car bluetooth connection.There are check boxes for connecting for both audio and cell. I have selected both.
    If I am listening to the car's radio, any calls are over the car's speakers but nothing else will work.
    If I choose Media for the input, with the Bluetooth selected, all content is available from my phone using the car's Bluetooth connection. Only negative is that the car's radio cannot be used.
    05-29-2014 08:06 AM
  11. BeansNY's Avatar
    Pretty sure this is standard for all cars. As mentioned, phone calls are handled by the Hands Free Bluetooth profile, while everything else (music, S Voice, GPS turn by turn voice, etc.) are are handled over the Audio profile.
    When the phone initiates anything over Hands Free, the car is designed to give it priority over everything else including the FM radio and other Aux inputs.
    For all other Bluetooth audio, the car has to be set to Aux-Bluetooth for it to be played through car speakers, including GPS, text alerts, etc.
    Hope this helps.
    06-01-2014 10:08 AM
  12. Frank Alberta's Avatar
    I now this is an old thread, but the problem the original poster noted is still going on (galaxy S7 Edge Verizon). And Android is the only phone operating system that handles Bluetooth connections this way. I came from a windows phone which works flawlessly over the Bluetooth handsfree for notifications, phone calls, and voice. The same is absolutely true for iOS (confirmed both today). The reason Siri and Cortana are setup this way is because the microphone is not listening when you are using the Bluetooth audio connection so no voice commands will work. With iOS devices and windows phone, it doesn't matter what input your car radio is on, the notification, navigation, and voice commands all go out and in over the phone protocol. Only android uses the Bluetooth audio connection and this is what has to be fixed.
    Does anyone know of any possible solutions to this problem?
    03-29-2016 08:42 PM
  1. G2 rom with wifi calling?
    By Benjamin Midyette in forum T-Mobile LG G2
    Last Post: 02-13-2014, 05:39 PM
  2. Replies: 2
    Last Post: 02-12-2014, 04:32 PM
  3. Problems with google now and dialing with pauses
    By Dexter9 in forum Motorola Droid MAXX
    Last Post: 02-12-2014, 03:18 PM
  4. Help with a Mototola Roadster 2 please
    By mrtwohands in forum Verizon Galaxy S III
    Last Post: 02-11-2014, 09:46 AM
  5. Knock doesn't work with Nova?
    By dp3103 in forum LG G2
    Last Post: 02-10-2014, 08:54 PM
