Results 1 to 8 of 8
    sjsmith1708's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default s4 running slow
    Hi.
    I have a s4 with 2gb avalable memory. When I click on things it seems to be really slow. Even when im sliding accross to the next page on home screen.
    Any help would be much appreciated
  2. #2
    mhinc's Avatar
    Posts
    Global Posts
    1,785 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: s4 running slow
    Quote Originally Posted by sjsmith1708 View Post
    Hi.
    Have you gone through the many other posts with how to increase the speed of your S4, such as disabling animations in Developer Mode?
  3. #3
    Mattb777's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey you should clear all you cache. This happened to me and when i cleared my cache it was like new. You can download an app or from your phone off, hold down the home but and volume up and press the power button a. Couple times until vibrate. The go to clear cache partition. Dont worry it wont delete anything such as contacts.
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Try clearing cache in recovery like mentioned above. I don't think the storage being full has any effect, unless you have junk files.
    Sent from my Galaxy S4 running SlimKat 4.4.2
  5. #5
    User 1212's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This happened to my S4 as well. Like most of the earlier posts I read, this occurred on Monday. I tried everything that was suggested in the posts-removed the SD card, un-synced a number of things, downloaded Wakelock Detector, and removed the battery for 30 minutes. Removing the battery helped a bit, but the next day, the battery was draining again. I started looking at what was slowest and the only thing I noted that was different from when the battery started draining - my email was taking a really long time to load. So, I deleted the email account on my phone. Then, on my laptop, I cleared out the deleted emails. Then I set up the email account on my phone, from scratch. I set it to retain only the emails for 2 weeks instead of 1 month (the default), and I have had no other issues with the battery draining. My emails load fast as lightning now and that little circle at the bottom of the screen doesn't turn endlessly. My email is not a gmail account, but it is "managed" by Google's gmail. I don't know if that makes a difference or not, but I hope this helps.
  6. #6
    c308682's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The previous explanation is incomplete.
    Do the following:
    Turn off phone
    Remove the battery and reinsert.
    Hold down the Home and Volume Up keys
    Press and hold the Power button while still holding the other keys.
    As soon as you see the Samsung logo, release all keys/buttons.
    Press on the Volume Down to scroll down to Wipe Cache Partition.
    Press the Power button to select it.
    Wait for a few minutes for the phone to clear the data.
    Then press the Power button to select reboot system now.
    Wait for your phone to reboot.
    wilmad and jpwilber like this.
  7. #7
    Dytryn808's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I just tried to do that and it said error. Do you have a clue on what that means or a way to find out what the error is?
  8. #8
    jpwilber's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    "Do the following:
    Turn off phone
    Wait for your phone to reboot."
    This worked. Thank you!
  1. What does "Device Management is running" mean?
    By kwitel in forum HTC One M7
    Last Post: 10-14-2016, 12:44 PM
  2. Samsung Galaxy S4 gets HOT while charging.
    By Aussrh420 in forum Samsung Galaxy S4
    Last Post: 07-16-2014, 06:51 AM
  3. Snatch up an S4 when the S5 comes out?
    By B. Diddy in forum Samsung Galaxy S5
    Last Post: 02-23-2014, 09:24 PM
  4. Run Keeper App
    By SandiW2552 in forum Bell Samsung Galaxy S4
    Last Post: 02-18-2014, 12:12 PM
  5. S4 GPe avalibility
    By 2Fredsone in forum Samsung Galaxy S4 Google Edition
    Last Post: 02-18-2014, 02:04 AM
