Galaxy s4 front facing camera
Aussrh420
21
I noticed that when I'm using the front facing camera I get no flash... Is it something in the setting or is it not possible to use the flash while the camera is facing you?
Sent from my SCH-I545 using AC Forums mobile app
garublador
1,135
My guess is they disable the flash when using the front facing camera because it will be facing the wrong way. So even if it did flash, it wouldn't help unless you used a mirror, at which point you might as well use the main camera.
cloudsofmana
