1. Felise Tan's Avatar
    Whenever my battery is fully charged, i have to unplug it. And when i unplug it, there seems to be a problem with the battery. When the battery is fully charged, it is at 100%. However, at around 90%, my phone will shut down on its own and when i try to turn it on, i can't. I can only turn it on when i connect it to the charger and turn on the switch. And when the phone is turned on, the battery percentage is 0%. This has been going on for quite some time. What is actually happening? Can someone please tell me. Thank you.
    02-22-2014 01:39 AM
  2. UJ95x's Avatar
    Welcome to Android Central
    Sounds like a bad battery. You can get it replaced at a carrier store. Shouldn't charge you for it...
    Sent from my Galaxy S4 running SlimKat 4.4.2
    ffejjj likes this.
    02-22-2014 01:41 AM
  3. Felise Tan's Avatar
    Thanks so muchh
    02-22-2014 08:56 PM
  1. Galaxy S4: Delete standard bell apps
    By Jenna Williams in forum Samsung Galaxy S4
    Last Post: 12-04-2014, 06:07 PM
  2. Lg g2 battery issues?
    By Ryan Atchason in forum LG G2
    Last Post: 02-21-2014, 11:46 PM
  3. Standard apps for S4 failing
    By EnergyPlus in forum Samsung Galaxy S4
    Last Post: 02-21-2014, 10:51 PM
  4. Standard apps for S4 failing
    Last Post: 02-21-2014, 10:48 PM
