Results 1 to 4 of 4
    UNCMo96's Avatar
    Posts
    Global Posts
    42 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Charging in Car with Screen on
    I have an S4 and my wife has an S3. Often when we take roadtrips we'll want to charge both phones while one is doing spotify and acting as a gps.
    I bought the following products:
    Scosche dual charger
    Amazon basics cable x 2
    When the screen is off and the phone is at rest it charges pretty rapidly. However, if I have the s4 as a gps with screen on it does not charge and actually loses charge (about 5% over 2 hours). From the reviews I read both on Amazon and on Wirecutter the these devices should work. I tried switching the cables (since I bought 2) and switching the inputs. Could I have a defective charger, or is this working as it should?
    Thanks.
  2. #2
    Chex313's Avatar
    Posts
    Global Posts
    662 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    6.0 Marshmallow
    Default Re: Charging in Car with Screen on
    Quote Originally Posted by UNCMo96 View Post
    Thanks.
    You got the right charger. So that leave's the cable. This cable might solve the problem...Amazon.com : Mediabridge 2.0 Micro-USB to USB Coiled Charging Cable (1.5-3 Feet) - A Male to Micro B with Gold-Plated Connectors : Computer Usb Cables : Computers & Accessories
    I'll let you read the reviews as to why this "charge only" cable works on Android devices better than a typical one. Though if you have other charging cables around(Like the one that came with the device). You can try them first, to see if they work. If so you know its the cable.
  3. #3
    Dave-in-Decatur's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You might look at the Duracell 5-in-1 charger that Office Depot carries (Duracell 5 In 1 Universal Cell Phone Charger by Office Depot). It does charge two devices, and shortly after I bought it last fall I was on the phone with Maps and GPS running constantly for an hour while I gave directions to people over the phone, and with the phone plugged into this charger it went from about 86% charge to 100%. Not saying you'll get the same result (especially if charging two devices at once), but I've been pleased with it. Bonus: it has plug-ins both for car outlets/lighters and for a regular wall outlet.
  4. #4
    mikew99's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unlike other USB devices that I have owned, the charging speed on the s4 is dependent on several factors:
    1) the charger itself (the Samsung AC charger puts out almost 2A);
    2) the specific port on the charger (some multi-port chargers output different current levels on different ports); and
    3) the USB cable (shorter, thicker, better-quality cables typically support higher current levels than thinner, longer ones).
    If any of the above is less than optimal, the S4 will charge more more slowly or not at all. You can use an app called Galaxy Charging Current to help you check how much current is reaching the S4 using the various chargers and cables you already have.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
  1. Home Button Stopped working with S View after kitkat update??
    By dacbeth in forum Sprint Samsung Galaxy S4
    Last Post: 04-23-2014, 04:44 PM
  2. Nexus 7: power off or leave it on? which is better?
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 02-25-2014, 03:48 PM
  3. lock screen
    By dave3389 in forum Google Nexus 5
    Last Post: 02-24-2014, 08:41 PM
  4. [Q] ad-hoc on Asus ME172V: cant replace wpa_supplicant
    By brendensen in forum General Help and How To
    Last Post: 02-24-2014, 06:06 PM
  5. Using an SD card with CM-11
    By petalmasher in forum Android 4.4 KitKat
    Last Post: 02-23-2014, 09:38 PM
