Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By srkmagnus
    Gabo_Es's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Question GS4 Sound not working AT ALL
    About a month ago, like a fool, I accidentally dropped my Galaxy S4 and the screen got 2 cracks on it, no big deal for me I can fix that. I picked it up right away and everything was working fine.
    That was until about last wednesday when all of a sudden anytime I go to make or answer a call I get no sound what so ever.
    I cant hear them they cant hear me.
    It doesnt ring through the phone but whoever I'm calling gets the call and can answer I just hear NOTHING and they cant hear me at all either.
    I called Samsung and they said it was due to physical damage so they wont fix it and my provider said the same thing.
    Im no stranger to fixing phones but ive never had this problem before.
    Has anyone had this happen to them before or can anyone give me any idea what I need to do to fix this
    I have tried:
    power cycling the phone
    cleaning the phone of any dirt
    and played with all the settings I could think of
    and more recently facory resetting the phone
    I NEED HELP!!
    Thank you in advance
  2. #2
    srkmagnus's Avatar
    Posts
    Global Posts
    13,761 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 4.4 (KitKat)
    Default Re: GS4 Sound not working AT ALL
    If you factory reset the phone and the issue remains it is likely hardware damage. If you open it up you'll see that everything audio is probably connected to the same board. That might have damage and needs replacement or might need check it's connections.
    UJ95x and Gabo_Es like this.
    Gabo_Es's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank You I will do that
  4. #4
    2Night's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had the same problem on my Samsung Galaxy S3. Till now (before the kitkat upgrade) I just call numbers like free services and press the speaker button and turn off the call. Then the phone work as fine (like a manually audio start) PS. My phone's glass is broken, I bought it second hand, I don't know what happened. Try to make a call and press speaker, maybe it will work for you!
  1. Replies: 7
    Last Post: 05-09-2015, 11:47 PM
  2. Phone stopped working after Cyanogenmod update. Please help!
    By steckymc in forum Samsung Galaxy S3
    Last Post: 07-29-2014, 09:52 AM
  3. Tim Cook spotted at S5 unveiling
    By oplix in forum Samsung Galaxy S5
    Last Post: 02-24-2014, 09:42 PM
