Galaxy S4: Missing Camera Shortcut KitKat
Bruninho98
19
Hello, I updated my Galaxy S4 i9505 to the KitKat since the first leaked test build, the NA1 and I got the camera shortcut on the lockscreen inicially and then it desapeared, dont know if it was when I updated to the test build NA5 or when it was, it just disapeared and now, still on the official final build it still does not show up! Can someone tell me how I get the camera shorcut back? Don't want other options to show the camera, just want that shortcut back. Thanks!
Re: Missing Camera Shortcut KitKat
Do you have the lockscreen turned on? I changed my phone lock settings to to none, and the camera shortcut disappeared, when I reset it back to the swipe lockscreen it reappeared.
Just to make sure I understand correctly.. After your phones screen times out, and you hit the power button to turn the screen back on, the camera shortcut is missing from this screen?
It gets me to the lockscreen and the little camera icon on the downside right isn't there, it should be...
Just solved! For the ones who have the same problem: "Go to system/csc/ and rename costumer.xml to costumer.xml.backup and then reboot... go to settings lockscree/shortcut/camera and done.use root browser for renaming." (For me it didn't wiped nothing as I read before, after renaming the shortcut appeared and nothing else changed.) ;)
Enviado do meu GT-I9505 atrav?s de Tapatalk
I have the i9505 myself and only installed the offical 4.4 KitKat update that was delivered with samsung kies and i don't have the camera short cut app nor can i duplicate the solution you made because it says (operation failed). Before this update i've noticed the i9505 doesn't have the same lock screen settings as every other model out there. Not sure if that could be the reason.
Sorry for the double post. I rooted my phone and was able to make the solution to work. Is it just me or does the battery drain just a bit faster now?
I have the Note 3 updated to KitKat 4.4 and realized when I used the gesture to unlock phone, the camera icon on the lock screen disappeared. Then switched back to swipe and it re-appeared. It seems to disappear with the PIN as well.
Can someone help me? I did not even "Shortcut" in the "ScreenLock". Android version: 4.4.2 (GT-I9505 Samsung Galaxy S4). Help me please! Thanks!
Maskin01
