08-11-2016 08:42 PM
26 12
tools
  1. Zdot7's Avatar
    The battery life on my current SGS4 isn't very good. I put it on charge before bed then wake up in the morning to find it at 85%. Furthermore, my phone battery is just overall draining. Around 1-2% of battery is draining every second. My brothers got a note 3 and the battery life on that is FANTASTIC. 20 hours straight and it's still only on 85%. Here's a pic of my battery usage-
    02-26-2014 05:51 PM
  2. sweaner's Avatar
    Likely a bad battery. Try a new one, suspect you will be OK. My battery lasts all day.
    Zdot7 likes this.
    02-26-2014 06:43 PM
  3. Zdot7's Avatar
    Thanks, btw I meant 1-2% every minute
    02-27-2014 01:10 PM
  4. ryan3067's Avatar
    I am having the same issue. I have deleted all apps I dont use and this is still occuring. Today I went to work with a fully charged battery and by 5pm it was under 30%. When I went into the battery screen it was showing the screen as 77% battery usage even with all the fancy options turned off and the brightness turned right down. I also downloaded wakelock detector and that was showing wakeup triggers of facebook 42 times and exchange services 32 times. Can anyone help?
    03-04-2014 05:22 PM
  5. FreeFool's Avatar
    Try uninstalling apps that you don't really need, like i don't use facebook and twitter that much, so i route these through Flipboard as that is bloatwarwe on my phone, so i may as well use it to its max. Use the stock email app rather than Outlook/Yahoo Mail etc. Disable other bloatware? Install a battery saver? the free Go Power Master seems to be ok for me, at least for turning off data while the phone is idle, this is where i seem to lose a lot of battery otherwise.
    03-05-2014 07:28 AM
  6. o4liberty's Avatar
    I find most smart phones to have very different battery life all depends on the user. I get pretty good life from mine almost 10 hours of heavy use.
    Sent from my SCH-I545 using Tapatalk
    03-05-2014 07:48 AM
  7. Zdot7's Avatar
    Does anyone know whether iphone 5s would have a better battery life when moderately using apps such as youtube, Instagram, Internet etc. with mobile data turned on and bluetooth and wifi turned off?
    03-05-2014 03:27 PM
  8. Zdot7's Avatar
    in other words, is the iPhone 5s battery life better than the SGS4's battery? or worse?
    03-05-2014 03:29 PM
  9. sasha's Avatar
    Did you try turning off location reporting that drains a lot of the battery?
    03-05-2014 03:34 PM
  10. Zdot7's Avatar
    Where's location reporting?
    03-05-2014 03:36 PM
  11. sasha's Avatar
    Go to settings + More, and location is there
    03-05-2014 03:40 PM
  12. jobega's Avatar
    Yes, I use an iPhone 5 and a Galaxy S4, and the iPhone at the end of the day still have 50% of charge, but the S4 at 3PM does not have battery, and I have to replace it, It's very annoying because the galaxy has a bigger battery and the use is the same.
    Zdot7 likes this.
    04-21-2014 05:58 PM
  13. worktorest's Avatar
    Well the S4 has a better screen resolution so it'll drain much faster than iphone. And the processor also. Just get some spare batteries and that will do it.
    04-22-2014 11:29 AM
  14. Norman Farrimond's Avatar
    You shouldn't need to purchase spare batteries as they should be made with the product source in mind, would you buy a computer with a poor power supply for the specification that is built in it?
    rfd177 likes this.
    05-06-2014 01:26 PM
  15. rfd177's Avatar
    If I need to remove all of the apps to keep my battery above 10% by 3 in the afternoon I might as well switch to a flip phone.
    05-07-2014 04:55 AM
  16. sgs4user's Avatar
    data connection drains battery like mad,
    try turning off data connection and using wifi where possible and this will extend battery life. plus turn off non essential programs which may be running in the background, use energy saving on screen display as this takes up the most power.
    you have to be on top of this phone and watch it as even if the mdc is switched off the phone will use it to download updates etc and if this doesnt go right the phone heats up (gets really hot and will kill sd card) and battery will drain in an hour this can also happen with some games and apps so beware.
    06-19-2014 04:02 AM
  17. doohsun's Avatar
    Not sure if you tried it yet I had the same problem for some reason something was draining my phone the android system was hovering around 50%. I was getting really frustrated. So I ended up backing up all my stuff and wiped the phone now the battery is amazing! i charged it last night from this morning i'm still on 90% and almost the end of my work day with bluetooth and wifi on wow!
    06-19-2014 03:02 PM
  18. jsbcarman's Avatar
    I've always been disappointed with the battery life of the s4. I recently purchased an anker 5200 battery and have used it for 3 days. The picture shows my average daily usage. I would like more but will z accept this for now. I took off charge at 5am
    Attached Thumbnails Samsung Galaxy S4 battery drain-screenshot_2014-06-19-21-03-28.jpg
    06-19-2014 08:04 PM
  19. doohsun's Avatar
    lol nice I got anker 7800mah it's crazy sick!
    06-20-2014 09:38 AM
  20. BigRoger's Avatar
    If you're power drain has suddenly appeared, try removing the SD card. Sounds crazy, but it was my last hope and it worked.
    My phone has done well. 12-16 hour days with lots of use, no problem.
    Two days ago, phone was noticeably hot and battery drain was very high.....probably would have made it about 3 hours.
    I tried turning off apps, bluettoth, GPS, wifi, etc. No improvement. Pulled out the SD card and it's back to be being nice and cool.
    My first two SD cards in this phone died after a couple weeks each. The last one is a Samsung card...and I've decided just to live with the on board storage. The S4 clearly doesn't handle SD cards very well.
    RR
    06-23-2014 03:16 PM
  21. seemak's Avatar
    Hi. My SGs4 is a year old. Till 4 days back the battery life was fine. I needed to charge my phone only once a day. Suddenly the battery started draining like crazy. Now I am charging my phone twice. I read and took all the steps by members of this thread , ie disabled most notifications , turned on power saving etc. but problem persists. Also earlier with no power saving mode and all notifications and apps functioning the battery was fine. So why the problem now? Do I need to change my battery?
    06-26-2014 02:35 AM
  22. Froide's Avatar
    I have the identical problem.
    The guy in Best Buy took a look at my phone, said it was a (common) battery problem. Since my phone's still in warranty (I bought it Dec 23; he looked at the phone July 2), he told me to call Samsung Support so they could replace it, free of charge.
    Samsung Suppor said they'd EXCHANGE the battery (free of charge). Wanted me to send them my battery and upon receiving it, would send me a new one, free. But the process can take 11 days!!!!! When I complained about that, they said to call my cellphone provider to see if they could give me a loaner.
    Sprint (my mobile service provider) doesn't do loaners. But gave me a $30 credit on my bill and urged me to use the money to buy a spare battery; the Sprint operator looked on the Internet and found a brand new OEM spare GS4 batter for $18, but still gave me the $30 credit.
    Liz Wagner likes this.
    07-06-2014 08:29 AM
  23. illegalsvk's Avatar
    I have had the same issue. I bought 1 year old phone and battery drain was as mentioned here. From 100 % to 90 % on idle in 40 minutes. Phone was wiped before, so I checked running applications and turned off "Story album". It's something from Samsung I never intended to use and now the battery is holding as it should.
    02-03-2015 03:44 PM
  24. Liz Wagner's Avatar
    I'm having the same problem with my Galaxy S4, but it's a new issue. It was always dead by the end of the day and needed nightly charging, but now it's dead by mid afternoon. I installed Battery Doctor and it listed a bunch of apps that are draining the battery. But every time I tell it to 'optimize' and, I assume, close all the processes on those apps, they just come back a few minutes later and continue to drain. The biggest drain seems to be Android's Assisted Dialing (which I can't uninstall or turn off) and AirWatch (it's a corporate phone).
    Does anyone know of any updates that could have happened to cause this? I'll check with my corporate guys too obviously but does anyone have any other ideas??
    02-03-2015 06:22 PM
  25. Tim Hammer's Avatar
    If the battery is good use a OEM charging cord not aftermarket sold on ebay, their smaller in diameter and charge at a much slower rate
    then original equipment.
    09-08-2015 11:18 AM
26 12
  1. Galaxy S5: Is the RAM a downgrade from the S4?
    By FutureKix in forum Samsung Galaxy S5
    Last Post: 03-03-2014, 10:28 AM
  2. S4 not letting me get kitkat OTA
    By Drsous11 in forum AT&T Samsung Galaxy S4
    Last Post: 02-27-2014, 12:40 AM
  3. Sony Z2 and Samsung Galaxy S5 compared in detail
    By Jay Holm in forum Samsung Galaxy S5
    Last Post: 02-26-2014, 11:23 PM
  4. samsung galaxy 3
    By karen hackford in forum Samsung Galaxy 3
    Last Post: 02-26-2014, 04:35 PM
  5. Using a galaxy note case for galaxy tab 2
    By hanchi in forum Samsung Galaxy Tab 2 10.1
    Last Post: 02-26-2014, 04:04 PM
