No. Assuming everything is in good working order, the absolute worst thing that could happen would be that your phone only charges at 500 mA, which might not be enough to charge the battery if you're using the phone at the time. There are apps that will show you the charging current you're getting (I use Galaxy Charging Current) if you're interested.
