Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By mysticmeg
    morganhuw's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy S4 fault - dropped phone and now screen doesn't work
    My girlfriend dropped her Galaxy S4 in a shop the other day and the phone has a full leather flip case around it. When she turns the phone on the bottom navigation lights works and the top LED light works but the screen doesn't.
    Anyone recommend a fix?
    I am convinced that a cable came loose for that to happen because there are no scratches or cracks on the screen or on the phone it's self.
    Thanks in advance
  2. #2
    mysticmeg's Avatar
    Posts
    Global Posts
    514 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy s4 fault - dropped phone and now screen doesn't work
    Definitely the cable has come loose
    TTD187 likes this.
    morganhuw's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Which cable would you suggest that is loose?
  4. #4
    mysticmeg's Avatar
    Posts
    Global Posts
    514 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy S4 fault - dropped phone and now screen doesn't work
    Hmmm... The main cable that connects the display to the motherboard. Quick search on YouTube will show you where it is.
  1. HTC One: Getting a refurbished phone?
    By BitchImFatJesus in forum HTC One M7
    Last Post: 04-03-2015, 03:36 AM
  2. Replies: 2
    Last Post: 07-02-2014, 04:13 PM
  3. Galaxy S3 screen not turning off when charging
    By 1823alex in forum AT&T Galaxy S3
    Last Post: 03-01-2014, 10:39 PM
  4. Touch screen on Galaxy S3 quit working
    By greenwse in forum Samsung Galaxy S3
    Last Post: 03-01-2014, 07:56 PM
  5. Replies: 7
    Last Post: 03-01-2014, 04:05 PM
