Results 1 to 2 of 2
    Default Quick Glance Issue
    Am I the only who has problems with this feature after Kit kat Update? Just in case this is the feature that with the phone on a flat surface if you move your hand over it will show you notifications and other stuff. After the Kit Kat Update when I move my hand over the phone it shows me the Quick Glance screen for fractions of a second and then it goes to the Lock Screen.
    I have checked everything and there is nothing different than before the update (I mean it was working great before), and I used this A LOT, so am I the only one with this issue?
    Thanks.
  2. #2
    Default Re: Quick Glance Issue
    I got the same problem, I just had stop using it because it started to get annoying.
    I now use DynamicNotifications.
  1. Google Play store issues
    By Aurelien Brandt in forum Samsung Galaxy S3
    Last Post: 03-06-2014, 01:26 AM
  2. keyboard issues
    By boos1906 in forum Verizon Samsung Galaxy S4
    Last Post: 03-05-2014, 05:35 PM
  3. alarm issues
    By Edwill86 in forum Moto X (2013)
    Last Post: 03-05-2014, 10:05 AM
  4. widget icon issue?
    By cpcxgsr in forum Moto X (2013)
    Last Post: 03-04-2014, 12:20 PM
  5. Google play store issue
    By Tommo15 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-04-2014, 12:28 AM
