1. bgl321's Avatar
    Has anyone had both devices? If so how would you compare the battery life of each? Are they relative close or does one last longer than the other (assuming you've used both and are comparing equal usage). Thanks in advance!
    03-06-2014 08:43 AM
  2. garublador's Avatar
    I have an S4 and my wife has a iPhone 5. They last about the same assuming I have Google Now with location based cards on and AutoLocation based Tasker profiles active and she does not have Google Now installed. She tried using Google Now the way I do and her battery life suffered a lot.
    So our experience is that the S4 has better battery life assuming the similar usage.
    bgl321 likes this.
    03-06-2014 09:19 AM
  1. Replies: 14
    Last Post: 06-23-2016, 06:47 AM
  2. The Alien Vs Human
    By irshad khan in forum Android Games
    Last Post: 04-08-2015, 07:38 PM
  3. Hidden apps are gone after updating my Galaxy S4 to 4.4.2
    By Younes Hicham in forum Android 4.4 KitKat
    Last Post: 12-04-2014, 05:34 AM
  4. Disable Vibration Galaxy Tab Pro 8.4
    By marcosmg in forum Samsung Galaxy Tab Pro 8.4
    Last Post: 12-02-2014, 08:13 PM
