1. Shadiii's Avatar
    I've bought my Samsung s4 a week ago and it's totally new but my battery drains so fast as am using it and it takes up to 5 hours to fully recharge please help
    03-09-2014 06:49 PM
  2. Remaxmatt's Avatar
    How many apps are you running at the same time? Turning off wifi and bluetooth should help. Adjust your screen brightness to either automatic or a lower setting.
    Games and video are the real battery hog for this phone.
    Using my S4
    03-09-2014 07:08 PM
  3. Shadiii's Avatar
    Yes but my brightness is about 40% and I have all the features off including blue tooth and I use the app called battery doctor to close all the apps running in the background and I barely get 3 hours of battery and it takes up to 5 hours to fully chargr
    03-09-2014 07:32 PM
  4. Shadiii's Avatar
    And I have power saving mode on as well
    03-09-2014 07:44 PM
  5. Remaxmatt's Avatar
    Both times seem excessive. Short for usage, and long for charging. Faulty battery?
    Using my S4
    03-10-2014 08:55 AM
  6. rockitdog23's Avatar
    Since you've only had it for a week, take it back and exchange it for a new one.
    03-10-2014 10:16 AM
  7. Sanjay Chandra's Avatar
    Battery should charge on an average of 1% per one minute and last 10% takes little more time.Totally it shouldn't take more than 105 minutes to reach 96 or 97% of battery level from 0%
    Use only charger and cable provided by Samsung.Other chargers won't work properly.
    Make sure that you update to 4.4.x if possible (4.3.x had somewhat bad battery life but 4.4.x battery life is much better)
    03-10-2014 10:28 AM
  1. Replies: 7
    Last Post: 11-29-2014, 02:55 PM
  2. Bricked Samsung Galaxy S2 i9100
    By PeteinSQ in forum Samsung Galaxy S II
    Last Post: 03-12-2014, 09:39 AM
  3. Galaxy S4: amazing battery performance
    By iFortWorth in forum Samsung Galaxy S4
    Last Post: 03-09-2014, 09:01 PM
  4. Galaxy S4: Email problems
    By Jeremy_12_Lee in forum Samsung Galaxy S4
    Last Post: 03-09-2014, 08:05 PM
  5. Samsung Galaxy S3 knocking Internet off in house
    By suey3b in forum Samsung Galaxy S3
    Last Post: 03-09-2014, 05:37 PM
