1. Millzey13's Avatar
    Please Help!
    Hi All
    Im not to new to this but im struggling and hopefully someone can shed some light.
    I updated yesterday to 4.4 in the uk on tesco mobile (O2) and i havent really seen many changes.
    I know alot of them are "under the hood" but everywhere i see is new wallpapers new screen app designs and new dialer design also with the new call id feature.
    I actually had an 0800 call earlier and it was same as old 4.3?
    Have i not done something or are these not features available to the S4 etc.
    Please can someone shed some light.
    ThNKS
    dAN
    03-13-2014 10:21 AM
  2. Saukrateaz's Avatar
    Are you sure you completed the ugrade? Check your softwar eversion and verify its 4.4
    You should definitely notice the differences, both in performance (although slight), and in visual.
    03-13-2014 10:30 AM
  3. Millzey13's Avatar
    Hi Thanks for quick reply, yea its 4.4.2 if i tap the build i get the kitkat easter egg thing!
    i can def notice some performance differences but nothing else, im sure the wigets have changed too but dont have that either its just the same?.
    The things i have noticed is that there is a couple of different options when removing an app, also the camera on the lock screen.
    is there new wallpapers, is there the dialler change? have you got this?
    Thanks
    03-13-2014 10:36 AM
  4. Sanjay Chandra's Avatar
    Thanks
    If you want to change dialer , you can use a 3rd party dialer such as this or contacts app like this
    That's the beauty of Android , You can customize many things if you don't like.
    btw , What color dialer are you having ?
    edit : i think you might be confused with 4.4 on Galaxy S5 which has many differences compared to 4.4 on Galaxy S4.
    03-13-2014 10:49 AM
  5. Millzey13's Avatar
    hi
    Yes im aware that can customise but its more irritatiing if i should have something and havent.
    No as far as im aware the kitkate 4.4 on galaxy s4 should have a new dialer icon and new functions such as caller id for 0800 etc numbers.
    Thanks
    03-13-2014 11:08 AM
  6. Rashawn29's Avatar
    hi
    Thanks
    That's only for the nexus 5,google kept it exclusive for them only.
    Sent from my Galaxy S4 via Android Central App
    Millzey13 likes this.
    03-13-2014 11:27 AM
  7. Millzey13's Avatar
    ok great thank you.
    03-13-2014 11:46 AM
  1. flashed g2 call log issue need help
    By tophius in forum Verizon LG G2
    Last Post: 10-14-2014, 11:53 PM
  2. HELP DONT KNOW WHAT TO DO - samsung note 2
    By turanga28 in forum Samsung Galaxy Note 2
    Last Post: 03-16-2014, 11:05 AM
  3. Help! I need a new phone
    By dragondraven14 in forum Motorola Droid 4
    Last Post: 03-13-2014, 08:16 PM
  4. Please Help! :)
    By Millzey13 in forum Android 4.4 KitKat
    Last Post: 03-13-2014, 12:07 PM
  5. Help with factory resetting my Galaxy S3
    By sallyasdf in forum Samsung Galaxy S3
    Last Post: 03-13-2014, 11:01 AM
