1. Platuni's Avatar
    Hello, I have a problem with my Samsung Galaxy S4. I was playing games on my phone and decided to let my phones battery go to 0%. I then tried to charge my phone, but the problem is it keeps vibrating every 2 seconds and is not able to turn on. I have not tried a new battery as I have to order one but was wondering if it could be a different problem?
    I have tried 2 chargers.
    03-13-2014 01:24 PM
  2. sasha's Avatar
    How long did you let it charge before trying to turn it on?
    03-13-2014 01:56 PM
  3. SAVAGE420's Avatar
    Yes a said above...how long?
    Let it sit for a couple hours and try again. Hold the Power button for 5 seconds.
    sasha likes this.
    03-13-2014 02:16 PM
  4. Platuni's Avatar
    I have tried to leave it charging overnight but it still won't turn on.
    When it's trying to charge it vibrates every 2 seconds.
    I don't know if it's to do with my battery or my phone.
    03-14-2014 05:14 AM
  5. SAVAGE420's Avatar
    Try pulling the battery out for a minute or so and try again.
    You can try shocking it as well. But be careful.
    Sent from my shed.
    03-14-2014 05:16 AM
  6. Platuni's Avatar
    Sent from my shed.
    Already tried this. I don't want to try shocking it
    I just want to know if it could be my battery or something to do with my phone. I think my battery
    03-14-2014 05:32 AM
  7. SAVAGE420's Avatar
    Definitely your battery. Grab a new one they're cheap.
    Let us know what's up when you try.
    Shocking it is worth a shot anyways. It will be out of the phone when you do it. So no harm to the phone.
    Good luck.
    Sent from my shed.
    03-14-2014 05:37 AM
  8. Platuni's Avatar
    Good luck.
    Sent from my shed.
    I've ordered one I will let you know soon as it arrives
    03-14-2014 05:43 AM
  9. Platuni's Avatar
    Ok first of all I want to say sorry for double post.
    I got my new battery and it's working fine. Only problem is when I charge it the battery percentage goes down and not up, but says it's charging. What could be the problem?
    Edit: I just tried turning my phone off to see if it would charge like that but it's still vibrating every 2 seconds. I also bought a new cable with the battery in case that was the problem.
    03-15-2014 06:52 AM
  10. SAVAGE420's Avatar
    That's weird man.
    When you say the percentage goes down, you say it goes into the negative past zero?
    Only happens when phone on and plugged in?
    Sent from my shed.
    Platuni likes this.
    03-15-2014 07:07 AM
  11. Sanjay Chandra's Avatar
    Take it to store and rectify it.
    Its better.Don't waste much money on changing batteries and charger etc. because we don't know what's the problem.
    Platuni likes this.
    03-15-2014 07:08 AM
  12. Platuni's Avatar
    That's weird man.
    Sent from my shed.
    No sorry I didn't explain well.
    For example my phone is on 58% battery and while it says it's charging the battery still goes down like now it's on 54%.4
    Yeah i'm going to bring it to a store if I can't fix it
    Edit: I just tried my brothers charger and it's doing the same thing
    03-15-2014 07:13 AM
  13. Platuni's Avatar
    I've just had a thought. Could it be the port where you plug in the charger?
    03-15-2014 08:23 AM
  14. Sanjay Chandra's Avatar
    Try using toothpick
    Platuni likes this.
    03-15-2014 08:38 AM
  15. yarnsrj's Avatar
    Sounds like bad charging port. Does your charging port also have a lot of "wiggle" instead of fitting securely? The charge you're seeing is most likely what was on the new battery when you inserted it, and your charging port is not working properly. If using the toothpick to clean away any debris didn't help, then a Trip to the store is in order.
    from "Ms Note 3" on Tapatalk
    Platuni likes this.
    03-15-2014 08:43 AM
  16. Platuni's Avatar
    Going to take it to store on monday thanks for the help everyone much appreciated.
    03-15-2014 08:54 AM
  17. Platuni's Avatar
    Ok so I decided to do a hard reset today then I was going to take it to the store tomorrow.
    I then went to charge my phone and there we go. It started charging. Somehow the hard reset worked!
    Also my old battery which I replaced is also now charging.
    Thanks for helping everyone
    Edit: Soon as I type this it's doing it again. I give up! Taking it to the store tomorrow
    03-16-2014 12:07 PM
  18. SAVAGE420's Avatar
    Crappy
    Sent from my shed.
    03-17-2014 12:03 AM
  19. SAVAGE420's Avatar
    So what's the good word Platuni?
    03-18-2014 12:30 PM
  20. Faisar Hussain's Avatar
    same here bro mine Samsung galaxy s4 is the same have you found out how to fix it i have tried 2 chargers aswell plz help someone
    07-08-2014 12:32 PM
  21. URNape2's Avatar
    OP please post any success you may have had, I am in the exact same situation (just intermittent vibrating). Thinking I'll have to change the USB port, what a pain. Hope that works...
    10-12-2014 04:03 PM
  22. Devlin85's Avatar
    I had this exact same problem, the battery fully depleted and when I went to charge it the only thing that would happen is a vibration every couple seconds, nothing would come up on the screen.
    I held the volume, home, and power buttons and booted into recovery mode and just hit reboot device, I didn't need to do the reset. I am back up and running now.
    Probably going to upgrade to a new model though, this one has been giving me trouble. Sensor issues, screen goes black like it thinks it's on a table and you're not using it, or up to your ear when on a call, but I'm not. Even disabled the bs features and still does it..
    11-12-2014 02:34 PM
  23. ZxElement's Avatar
    The funny thing is, I got mad at mine and hit it on the table and it turned right on XD
    04-14-2015 08:40 PM
  24. ckkhoo's Avatar
    Looks like it might be the power button.
    Here's the link for troubleshooting and solutions. You might need some simple electrical skills.
    04-26-2015 02:01 AM
  1. Replies: 7
    Last Post: 12-27-2014, 12:09 PM
  2. Turning on/off Airplane mode as system app
    By ohan in forum Android 4.4 KitKat
    Last Post: 10-20-2014, 05:00 AM
  3. Galaxy Note 3 Case Slim Armor View
    By Malkozaine in forum Sprint Samsung Galaxy S4
    Last Post: 03-20-2014, 11:18 AM
  4. I've deleted my android operating system on Galaxy Fit. HELP!
    By Alexghe966 in forum General Help and How To
    Last Post: 03-13-2014, 10:46 PM
  5. Can I use some apps on WiFi and some on my data?
    By PittsburghJake in forum Motorola Droid Ultra
    Last Post: 03-13-2014, 05:07 PM
