1. mmostafaei's Avatar
    After updating to Kitkat, my Samsung keyboard doesn't allow me to replace customizable key with a punctuation mark (i.e. "?" mark)
    Does anyone else have this problem?
    03-16-2014 11:40 AM
  2. STARGATE's Avatar
    Welcome to the forums!
    I'm not sure I understand your issue. Could you explain a little more so I can try to help you.
    03-16-2014 12:33 PM
  3. mmostafaei's Avatar
    Thanks!
    You used to replace the Customizable button (between Space and Sym buttons) to a punctuation mark. You could keep pressing the customizable button and change its function (as you can see in the help file on the first picture). However, I am missing this after updating to KitKat. I am wondering if anyone else has the same issue? I reset my keyboard and no luck.
    03-16-2014 12:40 PM
  4. STARGATE's Avatar
    Oh yes, I get you. That happened on my Sprint GS4 on an update before getting KitKat actually.
    I don't miss it, but I guess others would. Sorry but Samsung is most likely responsible for that one.
    Sent From Inside The TARDIS in a Galaxy S4 Away!
    mmostafaei likes this.
    03-16-2014 12:47 PM
  5. mmostafaei's Avatar
    I really miss that. I used to use it for "?" . Now I have to go to symbol and type "?" or have to keep the "." key so the "?" shows up. Makes it way slower to type.
    Funny enough, the help file still says you can change the customizable key to punctuation marks
    03-16-2014 12:58 PM
  6. STARGATE's Avatar
    Funny, on my keyboard, as you can see below, the ? symbol is with the m.
    03-16-2014 02:29 PM
  7. mmostafaei's Avatar
    Oh wow, that's odd. I am wondering why mine doesn't have that. What model of S4 you got? Mine is SGH I337M.
    03-16-2014 02:42 PM
  8. STARGATE's Avatar
    Mine is the Sprint version: SPH-L720.
    They're different versions but the keyboard is from Samsung so I don't see why it should be any different.
    I also have Android 4.4.2
    03-16-2014 02:47 PM
  9. mmostafaei's Avatar
    mine doesn't have many of those options (like the globe, etc.)
    03-16-2014 04:48 PM
  10. STARGATE's Avatar
    That globe is just a quick way to change the language; I have the keyboard in Spanish and English.
    Sent From My Galaxy Tab 3
    03-16-2014 04:54 PM
  11. STARGATE's Avatar
    Have you tried the Google keyboard?
    I really like it, and actually use it with my Galaxy Tab 3. But on my GS4 I rather use the stock Samsung KB because the easy access to the numbers and the main reason is the emoji.
    03-16-2014 04:57 PM
  12. alberto hernandez3's Avatar
    someone please give me the keyboard 4.4 stock, accidentally i deleted
    03-22-2014 12:47 AM
  1. Sprint Galaxy S4 Purple
    By NovaSS369 in forum Marketplace Archive
    Last Post: 05-04-2014, 10:34 PM
  2. Sprint Galaxy Note 3: Going to Europe In about a month
    By KingGinger55 in forum Sprint Samsung Galaxy Note 3
    Last Post: 03-28-2014, 10:29 PM
  3. Just Got A Galaxy Gear.
    By Zax1108 in forum Samsung Galaxy Gear
    Last Post: 03-17-2014, 08:45 PM
  4. Samsung Galaxy S3 keeps restarting
    By Killian Greville in forum Samsung Galaxy SIII I9300
    Last Post: 03-16-2014, 02:46 PM
  5. SAMSUNG NOTE 8.0- audio not working while making video- IMP
    By Beni Mahboob in forum Samsung Galaxy Note 8.0
    Last Post: 03-16-2014, 10:21 AM
