Results 1 to 23 of 23
Like Tree3Likes
  • 1 Post By iron56
  • 2 Post By iron56
  • 1 Post By popfx
  • 1 Post By lonswain
    iron56's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default How to remove the OTA downloaded Kitkat firmware?
    I have recently received the Kitkat 4.4 OTA download for Kitkat for my Galaxy S4. Having heard issues with the SDcard access by certain apps, I really woudl prefer to remain on Jelly Bean. However, having already received the firmware downloaded onto my S4, I keep getting reminders to update my firmware every 3 hours (maximum that I can delay it).
    Is there a way to delete the downloaded Kitkat 4.4 firmware? I don't have much space on my S4 internal storage and I would like to remove it as well as the irritating notifications. My S4 is not rooted.
    Thanks for any help!
    souleem likes this.
  2. #2
    Paul627g's Avatar
    Posts
    Global Posts
    17,762 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: How to remove the OTA downloaded Kitkat firmware?
    As far as I know you can't remove or get rid of the annoying update OTA notification. Its basically un avoidable outside of delaying/ignoring it like you have been doing.
  3. #3
    sho50's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The SD card issues are very real! KitKat 4.4.2 simply doesn't work right. Regretfully, Google has foisted a buggy beta "update" on its customers.
    Anger is natural, but we customers must demand that Google fix this travesty IMMEDIATELY, else face severe consequences (bad PR, fleeing customers, even legal action). Either provide a simple roll back to the far better 4.2 OS, or quickly fix the issues and re-release a functional KitKat product.
  4. #4
    gxgs's Avatar
    Posts
    Global Posts
    172 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by sho50 View Post
    Its not a bug, its how it works. Samsung just made it worse.
    AnandTech | Examining MicroSD changes in Android 4.4
    and there are many more articles explaining that.
    Quote Originally Posted by iron56 View Post
    Which variant of the s4 do you have?
  5. #5
    thatdude93's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I still havent recieved that update on my phone
    Sent from my SCH-R970C using Tapatalk
    iron56's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have a GT-i9505.
    Okay, I managed to get rid of the notifications by long pressing on the notification to invoke App Info and then Force Close it. It no longer bothers me, but judging from my remaining space in the internal storage, I still have 400mb of OTA downloaded firmware which I can't seem to find using ES File Explorer. Where is it?
    Quote Originally Posted by gxgs View Post
    souleem and defeedme like this.
  7. #7
    Paul627g's Avatar
    Posts
    Global Posts
    17,762 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Can't blame sdcard issues on Google, that is Samsung's department.
    FWIW, KitKat 4.2.2 runs great on my Nexus 7. I think we need to point more towards the OEMs and their custom skins/UI causing issues. But I will say there is room for improvement on Google's behalf too.
    Paul, Moderator Team Leader.
  8. #8
    JudH's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Paul627g View Post
    On the contrair, this is very much Google. It's Google that's now requiring OEMs to not bypass the card management stuff that Google put in 4.3 or earlier. It's original Google Android code that's now limiting apps to only writing to their own folder on external sdcards. It's Samsung, or LG, or Sony, that you can't blame this on.
  9. #9
    silverfang77's Avatar
    Lone Wolf
    Posts
    Global Posts
    1,185 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Will we still be able to store photos, videos and music on the microSD card?
  10. #10
    Rashawn29's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by silverfang77 View Post
    Yes but only with the built in apps.
    Sent from my Galaxy S4 via Android Central App
  11. #11
    popfx's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hi. Did you find a way to remove the firmware from your phone? I have the same problem. Thanks. P
    defeedme likes this.
  12. #12
    androidcentral8450's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by popfx View Post
    If your phones are rooted, download NoBloat Free. Once installed, click on the System apps section. Once in this section, scroll down until you see SamsungUpdates.apk AND SDM.apk. Click on each and choose whether you want to Disable or Delete (with or without backup). I would recommend simply disabling the apps in the event you ever want to upgrade in the future. I performed these steps months ago and have never been bothered again. Just keep in mind, this will only work if you are rooted.
  13. #13
    lonswain's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Assuming one is already rooted, can't you just remove (or rename) the update.zip file located in /cache/fota or do the apk's keep sending the message regardless?
  14. #14
    rtnuqrat's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unhappy Re: How to remove the OTA downloaded Kitkat firmware?
    I also can't find my current photos saved to my SD card and I use a Motorola Razr Maxx HD. If you are suggesting it's good business to do whatever updates regardless if they work with the most popular phone then that is shortsighted and is not customer oriented. I have been wanting an iPhone. I think now is the time.
  15. #15
    Photog237's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Exclamation Re: How to remove the OTA downloaded Kitkat firmware?
    Interesting that someone else lost their photos, I lost mine too after the upgrade...the auto upgrade at that. I have been talking with AT&T and all they can say is that it "shouldn't" remove personal data and that I should be backing up. Nothing I didn't already know, but I also said there should be a way to be notified that I have an update waiting rather than force it. If there is a way to keep the updates from occurring automatically, please let me know and I will make that change pronto.
    Good thing I did have some of the photos somewhere else...but that isn't the point. Had I known about an upgrade getting ready to happen, I would have backed up everything.
  16. #16
    ted fletcher's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am a 65 year old pensioner. I bought my wife a google nexus 5 phone for her birthday. It was great until Google without my knowledge or permission ruined it by downgrading the firmware to KITCRAP!!! She can no longer use her phone because after two years learning how to use Jelly Bean she now is faced with a completely new operating system which we didn`t ask for and don`t want. I am trying to get some good old fashioned CUSTOMER SERVICE from Google but it seems to be an alien concept to them. Consequently if they don`t contact me or do something about it I will take them to court for the cost of the ruined phone and my inconvenience. What may seem to Google to be an all singing all dancing wonder of modern technology is in fact to others a ruddy nuisance and they don't seem interested in helping either. There seems to be no way to contact them. All I can do is keep posting on forums until they notice that they have an unhappy customer and come down off their haughty perch to offer a mere customer some help.
  17. #17
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  18. #18
    Hossam Sherif's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: How to remove kies firmware update
    i want to remove samsung kies update from mt phone note3 sm-n9005 4G
  19. #19
    Renaldi VII's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How exactly did Google force you to downgrade to 'KitCrap'.... when the N5 never had Jellybean to begin with?
  20. #20
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by ted fletcher View Post
    Speaking of which, something tells me your wife did not have stock Jellybean on a Nexus based device, because without putting both under a microscope, it's difficult to tell them apart. Not much has changed between them, other than some under the hood stuff and tiny UI tweaks. In fact, they are so alike, the code number for KitKat is 4.4, a point revision above Jellybean (4.1, 4.2, and 4.3) - it shows that it really isn't all that different. If your wife was using a non Nexus phone, then that is a completely different matter - which wouldn't be Google's fault, because the UI of other OEMs can be very different from stock - which is what Google uses.
    Honestly, I think you are taking this a bit far. You're threatening to sue Google for the cost of your phone ($400?) and the non existent customer service ($400+; also that strikes me as strange as very customer support meeting I've had with them was quite pleasureable) because KitKat is too hard and no one will help you get Jellybean onto your phone (which makes little sense for Google, since Jellybean is 2 versions old now and it wouldn't make sense for them to make an outdated firmware on an already aging device)?
  21. #21
    Dev Dewan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Dear Sir,
    While playing with third party's apps to deactivate some of the files to save precious battery life - ever since i performed the action my mobile [Samsung Galaxy s4 mini] has stopped working showing applications detail for downloading. It could be probably i have deleted some of the important files unknowingly. However, can y guide me to re-download kitkat again to my mobile ?
    Dev
  22. #22
    edsta246810's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    *For those still without a solution!!*
    I just downloaded an app called 'CM Locker (boost and save power)'.
    This app is going to literally save your life, and your phone in terms of space, and junk on your phone. I also was a bit skeptical about the new update, and I updated the software, but then didn't want the actual update on my phone. Yes, you can hold the update notification down and force stop when going into settings to stop the notification, but you will still have this software on your phone, nowhere to be found, using up heaps of space!
    Once downloading CM locker, go into 'Big files found' when clearing Junk, and as I did, you will find this update software sitting there. You will have found it, and will be able to delete it!!! Then, it's happy days
    All the best!
  23. #23
    Darkskytm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs down Re: How to remove the OTA downloaded Kitkat firmware?
    yeah, another pishing destept. it`s not working at all...you`re just paid to make scam announcements. get a real life dude
  1. How to decline KK update?
    By JxPops in forum Samsung Galaxy Note 3
    Last Post: 06-25-2014, 01:09 AM
  2. Note 10.1 2014 - how to seperate photos with videos in gallery
    By Ess 069 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-20-2014, 02:19 PM
  3. My Android Phone...Jelly Bean 4.2, sms wont show even the persons name from phonebook ?
    By plainman007 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 03-18-2014, 01:31 PM
  4. Replies: 1
    Last Post: 03-18-2014, 10:00 AM
  5. What apps do you use to manage your databases on Android devices?
    By KateN in forum General News & Discussion
    Last Post: 03-18-2014, 04:20 AM
