1. Stormy1965's Avatar
    Im having a problem similar to one I saw posted in the S3 forum that didnt resolve my problem. I get a recurring sound similar to the one used on Fox News alerts, it fades in from the background and culminates in a resounding clanking sound. It happens quite frequently (at least once an hour) and does so without any accompanying notification message or icon. Ive tried all of the following without success:
    Disabled ALL application notifications
    Used the Blocking Mode to turn off notifications
    Turned off NFC
    Deleted Yahoo Mail
    The sound happens while sitting inactive, while listening to radio and while using applications. Curiously it hasnt happened while talking on the phone or texting but I do little of both. Its also louder than it should be for the volume setting and can be heard quite resoundingly even with the phone set at the lowest volume level. This is not only a nuisance but a problem as I like to keep my phone on overnight on the nightstand next to my bed. Any help would be greatly appreciated!
    03-19-2014 03:24 PM
  2. zedorda's Avatar
    Uninstall your apps reverse to the order you got them. It is likely a rogue app.
    03-19-2014 04:41 PM
  1. Replies: 24
    Last Post: 01-16-2015, 02:08 AM
  2. Verizon HTC One: Annoying recurring sign-in requests
    By Down with Apple in forum Verizon HTC One
    Last Post: 03-19-2014, 07:30 AM
  3. Vodafone Galaxy S4: Evernote Speech-to-text widget - turn sound off
    By ronbunzl in forum Vodafone Samsung Galaxy S4
    Last Post: 03-17-2014, 02:56 PM
  4. Replies: 0
    Last Post: 03-17-2014, 06:49 AM
  5. shutter sound disable in Note 3
    By Harshuvinod in forum Samsung Galaxy Note 3
    Last Post: 03-15-2014, 11:44 PM
