1. RichardHewlett's Avatar
    Hi, sorry for the q if it'd dumb, i'm new to android....
    Is this normal for the "Android System" and "Android OS" to be eating so much battery? I can't remember doing this prior to the Kitkat update.
    thanks
    03-19-2014 05:25 PM
  2. zedorda's Avatar
    Whats the screen on time? It would be a great pic to add. Just tap the screen 34% to get the pic.
    03-19-2014 05:42 PM
  3. RichardHewlett's Avatar
    I've charged it a bit since...
    03-19-2014 05:48 PM
  4. zedorda's Avatar
    No I don't think it is normal.
    03-19-2014 09:45 PM
  5. RichardHewlett's Avatar
    I'm letting it go all night, 10 hrs without doing anything after being fully charged... What % should it be in the am when i wake up. I left Wifi on...turned off GPS
    03-19-2014 09:48 PM
  6. zedorda's Avatar
    At your current rate you should see at least 40h with 4h of screen on time. With less screen time you could see 50h+.
    That is above avg.
    03-20-2014 09:23 AM
  1. Replies: 4
    Last Post: 04-19-2014, 03:32 PM
  2. Sprint LG G2: Battery sucks!
    By Julio Esteves in forum Sprint LG G2
    Last Post: 03-25-2014, 11:28 PM
  3. What is your battery status on your Note3
    By Szajda78 in forum Samsung Galaxy Note 3
    Last Post: 03-19-2014, 05:47 PM
  4. Replies: 1
    Last Post: 03-19-2014, 03:15 PM
  5. Replies: 0
    Last Post: 03-19-2014, 02:46 PM
