Results 1 to 8 of 8
    ahmedmabrouk's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default memory problem on S4
    Hello Android people
    so i recently got this S4 to my wife , looked great and everything but now it has this famous memory problem
    its GT-19500 version 4.2.2
    when i tap settings >>More>> storage it says total space 8.9 GB ,, now how come its just 8.9 g only ,, ???!! i bought this thing 16 G,, also i have application and data about 3.5 G in total and it says available 748MB only !!!! where is the rest ?
    also when i tap the task manager>> storage >> it says : system storage 15.27GB/16.00GB ,, why is there a diff in the memory calculations ?.. can this issue be resolved ? how ?
    how come i just bought this phone and its showing this huge utilization ?
    Thank you
  2. #2
    trucky's Avatar
    Posts
    Global Posts
    6,367 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: memory problem on S4
    The phone's own operation system and utilities consume space and have to reside somewhere. That's where your 16GB internal storage goes from 16GB to 8.9GB.
    Every hard drive or storage device (MicroSD) requires overhead to manage the file system. That's where your .73GB went on your external storage (MicroSD).
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by trucky View Post
    hello Trucky
    i have no external memory ,, what should i do ?
  4. #4
    trucky's Avatar
    Posts
    Global Posts
    6,367 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You don't have a MicroSD card inside your phone?
  5. #5
    Darthstorm528's Avatar
    Posts
    Global Posts
    927 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Your external memory port is inside the battery. You have to remove it to insert the SD card
    Sent from my iPhone using Tapatalk
  6. #6
    trucky's Avatar
    Posts
    Global Posts
    6,367 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Darthstorm528 View Post
    Well... close. It's under the battery cover, although it's always a good idea to remove the battery prior to inserting or removing a SD memory card.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yes i don't have external SD ,, only 16 G internal memory ,, what should i do to free up some space ? and where is all the 8G eaten ? i swear i have only like 3.5 G used ,, where the heck is the rest of the 8 G ?? so strange and annoying
  8. #8
    trucky's Avatar
    Posts
    Global Posts
    6,367 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ahmedmabrouk View Post
    Re-read post # 2. This normal.
  1. Having problems charging your Galaxy S3 CHARGING SOLUTION
    By Tom Caddick in forum Samsung Galaxy S3 I9300
    Last Post: 03-24-2014, 12:59 PM
  2. Why My HTC Status Can Not On ?
    By Jubril Akande Owowole in forum HTC Status
    Last Post: 03-24-2014, 09:51 AM
  3. How can i root my S4 clone
    By finalstorm001 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 03-24-2014, 04:31 AM
  4. Sound not on
    By SonDan in forum Google Nexus 7 Tablet (2012)
    Last Post: 03-24-2014, 03:42 AM
  5. Samsung galaxy s4 message notification in lockscreen problem?
    By pipenz11 in forum Samsung Galaxy S4
    Last Post: 03-24-2014, 01:20 AM
