1. cwiebe's Avatar
    Although I can't be completely certain, I think this stopped working with the 4.4.2 update.
    I use the Samsung headset with volume up/down and a play/pause button. I used to be able to answer a call by pressing the play/pause button. This now does nothing.
    Is there any way to restore this function? Thanks in advance.
    03-25-2014 08:19 AM
  2. Golfdriver97's Avatar
    Grasping at straws here, but when you plug in the headset, you should get a notification. When you tap on it, does that open up settings or options for the headset? Otherwise, something like that is embedded in the ROM and usually can't be changed.
    03-25-2014 08:47 AM
  3. cwiebe's Avatar
    The environment of the S4 is what makes it awesome, as well as a pain at times. There are so many configurable options.
    Sadly, plugging in the headset does not display a notification. But I wasn't imagining this, it did work at one time. Could it have been a third party app I configured and have forgotten about?
    03-25-2014 08:53 AM
  4. Golfdriver97's Avatar
    More likely it was something in a previous stock ROM. Did you get and update?
    From a Liquid Nexus 5
    03-25-2014 10:01 AM
  5. cwiebe's Avatar
    Yes. Recently upgraded to 4.4.2 . Are you aware of a third party app that would enable this?
    03-25-2014 10:12 AM
  6. Golfdriver97's Avatar
    No. Sorry.
    From a Sprint Moto X using AC Forums app
    03-25-2014 11:10 AM
  1. Replies: 7
    Last Post: 03-29-2014, 11:25 PM
  2. call blocker app on samsung query
    By Clementina Phillips in forum General Help and How To
    Last Post: 03-25-2014, 11:58 PM
  3. Google+ battery use when disablef
    By smiarmstrong in forum Google Nexus 5
    Last Post: 03-25-2014, 03:05 PM
  4. Replies: 6
    Last Post: 03-25-2014, 11:23 AM
  5. Beeping during all calls...
    By catattoo in forum Samsung Galaxy Note 3
    Last Post: 03-25-2014, 09:25 AM
