1. longcafe's Avatar
    Hi, recently installed 4.4.2 on my s4 via odin. I cant just charge my phone while its power off. When i plug in charger it keeps turning on. Any help please? Sorry if i posted wrong part of forum.
    devilrem likes this.
    03-28-2014 12:40 PM
  2. maricopa1963's Avatar
    if it doesn't go back to sleep after a few seconds. .. look in settings. ..developer settings. There's a check box that keeps the phone awake when plugged in.
    03-28-2014 03:12 PM
  3. longcafe's Avatar
    if it doesn't go back to sleep after a few seconds. .. look in settings. ..developer settings. The a check box that keeps the phone awake when plugged in.
    03-29-2014 12:03 AM
  4. longcafe's Avatar
    It does.. already checked dev. settings. When i plug in charge always powers up.
    03-29-2014 12:12 AM
  5. 4runnerbrett's Avatar
    Have you tried plugging it in and then turning off?
    03-29-2014 11:03 AM
  6. longcafe's Avatar
    Yes but it keeps turning on.
    03-29-2014 10:06 PM
  7. Vicky Sofyan's Avatar
    did you find the solution?
    07-31-2014 12:32 AM
  8. Stewart Robbins's Avatar
    I have the same issue, I'm running 4.4.2 with an old boot loader so I avoided Knox. Any ideas?
    07-31-2014 02:19 PM
  9. devilrem's Avatar
    Hello, I am having the same issue with my i9500. Were you able to find solution?
    08-11-2014 11:35 AM
  1. Verizon Galaxy S4: Turn off LTE and limit to 3G/1X
    By mattc12 in forum Verizon Samsung Galaxy S4
    Last Post: 05-10-2014, 08:21 PM
  2. Replies: 2
    Last Post: 03-31-2014, 08:27 PM
  3. Galaxy S4 says it's charging but it WON'T!
    By cberry30 in forum Samsung Galaxy S4
    Last Post: 03-28-2014, 03:28 PM
  4. Keyboard/ Emoji on KitKat?
    By gadget22 in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-28-2014, 11:18 AM
  5. HTC One (M8): No screen on time in battery usage?
    By justlaxin13 in forum HTC One M8
    Last Post: 03-28-2014, 11:01 AM
