1. the sufi's Avatar
    Hello, I am new on this forum.
    I have a S4 korean version. It's SHV-E300L. I have updated it to kitkat 4.4.2 few days ago using kies. And now it keeps rebooting (around 10-12 times a day), and huge overheating! Any solution? Or should I roll back to 4.3?
    Shabir Bhat1 likes this.
    03-31-2014 07:10 AM
  2. Szajda78's Avatar
    Try too reset the phone too factory settings and then try and see if your S4 still overheating. If yes then go back too your reseller and send the phone for repering.
    Skickat frn min SM-N9005 via Tapatalk
    03-31-2014 07:32 AM
  3. Almeuit's Avatar
    I would try a factory reset first to see if that fixes the issue.
    Sent from my T-Mobile Note 3 using AC Forums.
    03-31-2014 07:49 AM
  4. the sufi's Avatar
    I did factory reset. But it did not solve the problem. And since yesterday, I can't even uninstall any app! It stacks at uninstalling and does nothing else!!! Any solution please?
    05-02-2014 02:07 PM
  5. chadfs's Avatar
    I have the same problem with my Sprint S3 4.42 upgrade, did you find a solution? I have already wiped/reset my phone. Thanks, Chad
    05-25-2014 03:38 PM
  6. Rohael DOUGLAS's Avatar
    I bought an unlocked Galaxy S4 and it kept restarting up to 5 or more times daily, i eventually disabled auto updates, and it's been a week now and no restarting..let me know if it works for you.
    02-10-2016 06:19 AM
  1. gray pics in download folder became normal again after restarting?
    By preppystud in forum Google Nexus 7 Tablet (2013)
    Last Post: 04-04-2014, 02:09 AM
  2. KitKat Updated
    By jstasen in forum Sprint LG G2
    Last Post: 04-02-2014, 09:48 PM
  3. problem with signchronizing
    By maxwell adugyamfi in forum HTC One X
    Last Post: 03-31-2014, 09:31 AM
  4. KitKat update
    By justinlee in forum Orange HTC One
    Last Post: 03-31-2014, 06:30 AM
