1. Ur_Face2014's Avatar
    So this is a screen shot of a menu that keeps popping up whenever I use the, back out of app button. Doesn't matter what I hit, because it still keep asking me and I don't know how to make it stop. Any help would be great. I am using a Galaxy S4.
    Attached Thumbnails TouchWiz Menu that never stops popping up PLEASE help!-1520721_10152436729671747_1326189715_n.jpg
    04-02-2014 03:41 PM
  2. Rashawn29's Avatar
    Click on always
    Sent from my Galaxy S4 via Android Central App
    04-02-2014 09:23 PM
  3. alexcolka's Avatar
    And then try restarting the phone
    Sent from my GT-I9500 using Tapatalk
    04-03-2014 11:28 AM
  4. jsice9's Avatar
    Did you updated to kit kat ready?
    04-03-2014 03:58 PM
  5. jsice9's Avatar
    If you already updated to kit kat then do this...... menu - settings - more - default applications - home, Make sure you only have TouchWiz Home and TouchWiz easy Home if anything else delete that option. I had Outlook option after I did kit kat update , once I deleted Outlook problem went away. Good luck
    04-03-2014 04:12 PM
  6. mhinc's Avatar
    You may have also disabled something in your Applications that was controlling this.
    04-03-2014 06:21 PM
  7. Ur_Face2014's Avatar
    Click on always
    I do and it doesn't help, it seems like it just doesn't save my answer, just keeps asking me this for every app I use, when I want to exit, also asks me when I restart my phone that same question before it loads.
    04-04-2014 07:29 PM
  8. mhinc's Avatar
    I will say this again. Have you gone in an disabled apps? Either by yourself or with an app assist such as "Clean Master"
    You have have disabled something that controls your choice for TouchWiz
    04-05-2014 10:13 AM
  9. akacheesy's Avatar
    deleting outlook connect seems to have sorted it for me, temporarily.......
    07-10-2014 02:35 AM
  10. Amanda Poss's Avatar
    I had the same issue and this fixed it. It was actually being caused by an app I installed that was showing up in my default apps.
    02-11-2015 09:49 AM
  11. snobizz's Avatar
    I touchWiz a ok app to have on my phone. I'd never seen or heard of it before it pop up on my phone. I taught I accidently downloaded a malware that I cannot get rid of .
    03-20-2015 11:55 AM
  12. Ur_Face2014's Avatar
    I have done "Always" every time for months. "Doesn't matter what I hit, because it still keep asking me and I don't know how to make it stop."
    09-13-2015 09:49 PM
  13. sachit's Avatar
    Thanks for helping. This problem ceased instantly i used cheetah clean master. some malware somewhere in junk files was causing it.
    02-05-2016 01:40 PM
  1. Replies: 7
    Last Post: 02-06-2015, 06:02 AM
  2. How to make the phone shut up!
    By Cane Prevost in forum Moto X (2013)
    Last Post: 07-22-2014, 07:29 PM
  3. the G3 seems like quite a step up if these specs pan out
    By xgman in forum Rumored Devices Lounge
    Last Post: 04-05-2014, 10:16 AM
  4. Unfortunately RakDroid by Raketu has stopped
    By zoheb Khan in forum Samsung Galaxy S4
    Last Post: 04-03-2014, 01:50 AM
