Screen Randomly Wakes Up/Unlocks On Own in Pocket - Galaxy S4 KitKat
xunlistedx
Hello,
I've had the Galaxy S4 with T-Mobile since the day it came out and never had any problems until recently. The screen has been randomly unlocking/waking up on its own in my pocket. It will stay locked at times and will be unlocked with my home screen on at times.
I do not and never have had any of the motion gestures on and just use the "swipe" function to unlock. I also changed to a PIN unlock and it was still happening.
I'm not sure if this is from the KitKat update, an updated app, sensor problem, or if there is something wrong with the phone.
Please advise if anyone has had similar problems and have found a solution.
Thanks in advance!
Lucy Davies
1,146
I had a similar thing happen with my first S4 but it was on jelly bean not kit kat. It was in my pocket & it must have unlocked itself as I had a video of blackness but could hear me & my friend talking. I was wondering if it was something to do with me enabling the sensitivity of the screen so I could answer my phone with gloves on.
yairgo
I've had the same problem and can't figure out what is going on. Is anyone else still seeing this issue?
Normally the only reason that I find out that the screen is on is because the phone with start to get really hot in my pocket. I even have the S-View flip cover
Tuon Can
4
I have found the solution after experiencing a similar problem myself. What happened is the phone thinks it has the s view cover on. When there is a change in light setting it thinks the s view cover was opened so it unlock the phone for you. To disable this feature you would go to Settings > Accesory > unchecked Automatic unlock.
Cheers!
Tuon
shaundiesel
165
Cheers!
Tuon
This, unfortunately, is not true. The S View cover (auto on/off) is based on a magnet in the cover, not a change in light.
I am experiencing this issue as well, and I do not have a fix still. My phone just randomly wakes up, but stays on the lock screen. Very frustrating.
ellisroy
85
Try out gravity screen. Download from xda or play store. Turns off/on screen using the phones sensors. It's meant for us lazy folks who don't want to use the power button. XDA site gives good info on use. Not sure if this is your solution
kerokekerol
